I want to use this piece of code or any piece of code that can give me the min_x, min_y, min_z, max_x, max_y, max_z.
So, in Isaac Sim Script Editor, I can use this told to me by @toni.sm
from omni.isaac.core.utils.stage import get_current_stage, open_stage
import omni.isaac.core.utils.bounds as bounds_utils
import omni.isaac.core.utils.prims as prims_utils
import numpy as np
ENV_URL ="omniverse://localhost/NVIDIA/Assets/Isaac/2022.2.0/Isaac/Samples/Replicator/Stage/full_warehouse_worker_and_anim_cameras.usd"
open_stage(ENV_URL)
stage =get_current_stage()
floor_prims = [x.GetPath() for x in stage.Traverse() if "SM_floor" in x.GetName() and prims_utils.get_prim_type_name(x.GetPath()) == "Xform"]
print('dir floor_prims: ', dir(floor_prims))
bb_cache = bounds_utils.create_bbox_cache()
combined_range_arr = bounds_utils.compute_combined_aabb(bb_cache, prim_paths=floor_prims)
min_x, min_y, min_z, max_x, max_y, max_z = combined_range_arr
How can I do the same in Omniverse Code Script editor?
Here’s the error I get if I use same code in Omniverse Code since we don’t have access to Isaac packages.
I am able to get the stage from the omni but not the bounding box.
import carb
import omni.usd
#from omni.isaac.core.utils.stage import get_current_stage, open_stage
import numpy as np
#open_stage(ENV_URL)
result, error = omni.usd.get_context().open_stage_async(ENV_URL, load_set=omni.usd.UsdContextInitialLoadSet.LOAD_NONE)
carb.log_info(f"Opened stage {stage} with result {result}")
#stage = get_current_stage()
I also searched for the code of bounds_util and prims_util in isaac and couldn’t find the source code.
(base) mona@ard-gpu-01:~/.local/share/ov/pkg/isaac_sim-2022.2.0$ rg "bounds_util"
(base) mona@ard-gpu-01:~/.local/share/ov/pkg/isaac_sim-2022.2.0$ rg "prims_util"
I can’t find any methods for compute_combined_aabb in omniverse code. Can you please help me with that?
import carb
import omni.usd
# import omni.isaac.core.utils.bounds as bounds_utils
# import omni.isaac.core.utils.prims as prims_utils
import numpy as np
#result, error = omni.usd.get_context().open_stage(ENV_URL, load_set=omni.usd.UsdContextInitialLoadSet.LOAD_NONE)
omni.usd.get_context().open_stage(ENV_URL)
#floor_prims = [x.GetPath() for x in stage.Traverse() if "SM_floor" in x.GetName() and prims_utils.get_prim_type_name(x.GetPath()) == "Xform"]
floor_prims = [x.GetPath() for x in stage.Traverse() if "SM_floor" in x.GetName() ]
print(floor_prims)
#bb_cache = bounds_utils.create_bbox_cache()
#combined_range_arr = bounds_utils.compute_combined_aabb(bb_cache, prim_paths=floor_prims)
#min_x, min_y, min_z, max_x, max_y, max_z = combined_range_arr
bbox = omni.usd.get_context().compute_path_world_bounding_box(floor_prims)
min_x, min_y, min_z, max_x, max_y, max_z = bbox
print("bbox is: ", bbox)
The error I get is:
TypeError: compute_path_world_bounding_box(): incompatible function arguments
I am aware I should find something like compute_combined_aabb as in Isaac Sim package however didn’t find something similar.
Also, could you please confirm that both of the following yield same results? I don’t have access to prims_path in Omniverse Code and couldn’t find something similar.
print(floor_prims)
Hi @mona.jalal
If you look at the definition of the compute_combined_aabb method, it is possible to track and unwrap its implementation to use only the USD API as follow:
# with prim_paths as a list[str]
bbox_cache = UsdGeom.BBoxCache(time=Usd.TimeCode.Default(), includedPurposes=[UsdGeom.Tokens.default_], useExtentsHint=True)
total_bounds = Gf.BBox3d()
for prim_path in prim_paths:
prim = stage.GetPrimAtPath(prim_path)
bounds = bbox_cache.ComputeWorldBound(prim)
total_bounds = Gf.BBox3d.Combine(total_bounds, Gf.BBox3d(bounds.ComputeAlignedRange()))
b_range = total_bounds.GetRange()
combined_aabb = [*b_range.GetMin(), *b_range.GetMax()]
system
Closed
March 31, 2023, 9:52am
5
