How to Access Ground Truth Environment Geometry in IsaacLab
Hi NVIDIA Team,
I’m currently working on a deep learning project using IsaacLab, and I want to generate training data for a scene reconstruction model. The idea is to use sensor data (RGB, depth, LiDAR) from a robot (e.g., ANYmal-C) as input, and train a model to reconstruct the surrounding terrain or environment in 3D.
✅ My Setup:
  • IsaacLab with TerrainImporterCfg to procedurally generate terrains (e.g., rough terrain).
  • A robot equipped with multiple cameras or raycasters.
  • I want to pair sensor data with ground-truth 3D geometry from the environment.
❓ My Key Question:
What is the proper or recommended way to directly access the terrain/environment geometry (i.e., full 3D point cloud or mesh) for ground truth labeling?
📌 Specifically:
  • If terrain is spawned via TerrainImporterCfg, is it expected to be a Mesh prim under a known path like /World/ground?
  • Are there tools/utilities in IsaacLab or Isaac Sim to extract the mesh vertices from the terrain (in world coordinates)?
  • If the terrain or other objects are not Mesh types, is there a recommended way to convert or sample them for GT data?
👀 What I’ve Tried:
  • Traversing the USD stage to find Mesh prims.
  • Using UsdGeom.Mesh(...).GetPointsAttr().Get() and transforming to world coordinates.
  • Found that many scene objects are Xform or Cone types, which are not directly sampleable.
  • Sometimes terrain prims don’t appear at all in the stage (e.g., /World/ground is missing).
🎯 My Goal:
For every simulation frame, generate a pair:
  • Input: Sensor data from the robot (e.g., RGB, depth).
  • Ground Truth: Accurate 3D point cloud of the environment near the robot.
What’s the best practice for this in IsaacLab?
Thank you so much in advance — any pointers or sample code would be appreciated!
I can only encourage you to resubmit this in our GitHub repository Discussions. Thank you for your interest in Isaac Lab. To ensure efficient support and collaboration, please submit your topic to its GitHub repo following the instructions provided on Isaac Lab’s Contributing Guidelines regarding discussions, submitting issues, feature requests, and contributing to the project.
We appreciate your understanding and look forward to assisting you.
