I want to get the ground truth pose of robot based on ros2 in isaac simulator.
( If it’s impossible, It doesn’t have to be ros2 based… )
So until now, i was trying to make the tf message ( map to base_link) based on omnigraph.
But I only reproduced omnigraph to receive tf message like ( map to odom, odom to base_link …)
However, I found the information that tf data is not ground truth.
- Isaac PoseTree Inconsistent worldTrobot - Carter Sim - #2 by d20.hall
Setting Up Transformations — Navigation 2 1.0.0 documentation
→ in here, they said transform (map → odom) is usually provided by a different ROS package dealing with localization and mapping such as AMCL ( below figure )
- **If then, Is there any method that can get the ground truth pose of robot in isaac simulator based on ros2? ( If it’s impossible, It doesn’t have to be ros2 based.) **
To sum up :
- I want to get the gt pose of robot using ros2 in isaac sim.
- Is there any methods for getting the GT Pose using ros2?
- And also Is tf data ground truth? ( I understood above page said that is not gt…). If then, How can i get the gt?
- I also found there is get_world_pose() function, So if i use this function, Could i get the gt pose?
If Anyone who know this problem, Please help me!!
( I heard that these questions are related to SDK… so I’m uploading this topic in here… ! )
Thank you so much!
