Hi, WayneWWW,
Here are the log :
1: primary kernel
Retrieving file: /boot/initrd
0 bytes read in 59 ms (0 Bytes/s)
Retrieving file: /boot/Image
20902448 bytes read in 526 ms (37.9 MiB/s)
append: root=/dev/mmcblk0p1 rw rootwait console=ttyS0,115200n8 console=tty0 OS=l4t fbcon=map:0 net.ifnames=0 androidboot.modem=none androidboot.serialno=04229170493060008000 androidboot.security=non-secure tegraid=21.1.2.0.0 ddr_die=2048M@2048M ddr_die=2048M@4096M section=256M memtype=0 vpr_resize usb_port_owner_info=0 lane_owner_info=0 emc_max_dvfs=0 touch_id=0@63 video=tegrafb no_console_suspend=1 debug_uartport=lsport,0 earlyprintk=uart8250-32bit,0x70006000 maxcpus=4 usbcore.old_scheme_first=1 lp0_vec=0x1000@0xff2bf000 nvdumper_reserved=0xff23f000 core_edp_mv=1125 core_edp_ma=4000 gpt android.kerneltype=normal androidboot.touch_vendor_id=0 androidboot.touch_panel_id=63 androidboot.touch_feature=0 androidboot.bootloader=00.00.2014.50-t210-fadd1be5 androidboot.verifiedbootstate=orange root=/dev/mmcblk0p1 rw rootwait
Flattened Device Tree blob at 83100000
Booting using the fdt blob at 0x83100000
reserving fdt memory region: addr=80000000 size=20000
Using Device Tree in place at 0000000083100000, end 00000000831affa7
Starting kernel …
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Initializing cgroup subsys cpu
[ 0.000000] Initializing cgroup subsys cpuacct
[ 0.000000] Linux version 4.4.38 (tonie@TonieDesktop) (gcc version 4.8.2 (GCC) ) #45 SMP PREEMPT Wed Jan 24 18:09:04 CST 2018
[ 0.000000] Boot CPU: AArch64 Processor [411fd071]
[ 0.000000] Reserved memory: initialized node vpr-carveout, compatible id nvidia,vpr-carveout
[ 0.000000] Reserved memory: initialized node iram-carveout, compatible id nvidia,iram-carveout
[ 0.000000] Reserved memory: initialized node ramoops_carveout, compatible id nvidia,ramoops
[ 0.000000] cma: Reserved 16 MiB at 0x00000000fdc00000
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.0 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] PERCPU: Embedded 17 pages/cpu @ffffffc0ffe40000 s31360 r8192 d30080 u69632
[ 0.000000] CPU features: enabling workaround for ARM erratum 832075
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 1027072
[ 0.000000] Kernel command line: root=/dev/mmcblk0p1 rw rootwait console=ttyS0,115200n8 console=tty0 OS=l4t fbcon=map:0 net.ifnames=0 androidboot.modem=none androidboot.serialno=04229170493060008000 androidboot.security=non-secure tegraid=21.1.2.0.0 ddr_die=2048M@2048M ddr_die=2048M@4096M section=256M memtype=0 vpr_resize usb_port_owner_info=0 lane_owner_info=0 emc_max_dvfs=0 touch_id=0@63 video=tegrafb no_console_suspend=1 debug_uartport=lsport,0 earlyprintk=uart8250-32bit,0x70006000 maxcpus=4 usbcore.old_scheme_first=1 lp0_vec=0x1000@0xff2bf000 nvdumper_reserved=0xff23f000 core_edp_mv=1125 core_edp_ma=4000 gpt android.kerneltype=normal androidboot.touch_vendor_id=0 androidboot.touch_panel_id=63 androidboot.touch_feature=0 androidboot.bootloader=00.00.2014.50-t210-fadd1be5 androidboot.verifiedbootstate=orange root=/dev/mmcblk0p1 rw rootwait
[ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes)
[ 0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes)
[ 0.000000] Memory: 3372628K/4173824K available (11013K kernel code, 1808K rwdata, 6276K rodata, 1208K init, 644K bss, 96684K reserved, 704512K cma-reserved)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] vmalloc : 0xffffff8000000000 - 0xffffffbdbfff0000 ( 246 GB)
[ 0.000000] vmemmap : 0xffffffbdc0000000 - 0xffffffbfc0000000 ( 8 GB maximum)
[ 0.000000] 0xffffffbdc2000000 - 0xffffffbdc6000000 ( 64 MB actual)
[ 0.000000] fixed : 0xffffffbffa7fd000 - 0xffffffbffac00000 ( 4108 KB)
[ 0.000000] PCI I/O : 0xffffffbffae00000 - 0xffffffbffbe00000 ( 16 MB)
[ 0.000000] modules : 0xffffffbffc000000 - 0xffffffc000000000 ( 64 MB)
[ 0.000000] memory : 0xffffffc000000000 - 0xffffffc100000000 ( 4096 MB)
[ 0.000000] .init : 0xffffffc001163000 - 0xffffffc001291000 ( 1208 KB)
[ 0.000000] .text : 0xffffffc000080000 - 0xffffffc001162c04 ( 17292 KB)
[ 0.000000] .data : 0xffffffc0012ab000 - 0xffffffc00146f230 ( 1809 KB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] Build-time adjustment of leaf fanout to 64.
[ 0.000000] RCU restricting CPUs from NR_CPUS=64 to nr_cpu_ids=4.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=4
[ 0.000000] NR_IRQS:64 nr_irqs:64 0
[ 0.000000] /interrupt-controller@60004000: 192 interrupts forwarded to /interrupt-controller
[ 0.000000] enable_t210_agic_clks:106 ape clocked & reset cleared
[ 0.000000] clk_cbus_recalc_rate: no gbus parent
[ 0.000000] kmemleak: Kernel memory leak detector disabled
[ 0.000000] Architected cp15 timer(s) running at 19.20MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x46d987e47, max_idle_ns: 440795202767 ns
[ 0.000005] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
[ 0.001765] Console: colour dummy device 80x25
[ 0.002638] console [tty0] enabled
[ 0.002670] Calibrating delay loop (skipped), value calculated using timer frequency.. 38.40 BogoMIPS (lpj=76800)
[ 0.002707] pid_max: default: 32768 minimum: 301
[ 0.002793] Security Framework initialized
[ 0.002814] SELinux: Initializing.
[ 0.002922] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.002947] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.003608] Initializing cgroup subsys freezer
[ 0.003639] Initializing cgroup subsys debug
[ 0.003904] CPU0 ipc=1024
[ 0.003938] CPU1 ipc=1024
[ 0.003970] CPU2 ipc=1024
[ 0.004002] CPU3 ipc=1024
[ 0.004069] ASID allocator initialised with 65536 entries
[ 0.027288] tegra-id: chipid=22117.
[ 0.027319] tegra-id: opt_subrevision=0.
[ 0.027350] Tegra Speedo/IDDQ fuse revision 4
[ 0.027370] Tegra: CPU Speedo ID 7, SoC Speedo ID 0, GPU Speedo ID 2
[ 0.027391] Tegra: CPU Process ID 0, SoC Process ID 0, GPU Process ID 0
[ 0.027412] Tegra: CPU Speedo Value 2006, SoC Speedo Value 1940, GPU Speedo Value 2024
[ 0.027439] Tegra: CPU IDDQ Value 1752, SoC IDDQ Value 2172, GPU IDDQ Value 2550
[ 0.027482] Tegra Revision: A02 SKU: 0x17 CPU Process: 0 SoC Process: 0
[ 0.028922] DTS File Name: ../arch/arm64/boot/dts/../../../../../../hardware/nvidia/platform/t210/jetson/kernel-dts/tegra210-jetson-tx1-p2597-2180-a01-devkit.dts
[ 0.028967] DTB Build time: Jan 24 2018 17:36:57
[ 0.044795] CPU1: Booted secondary processor [411fd071]
[ 0.056763] CPU2: Booted secondary processor [411fd071]
[ 0.068761] CPU3: Booted secondary processor [411fd071]
[ 0.068846] Brought up 4 CPUs
[ 0.068913] SMP: Total of 4 processors activated.
[ 0.068936] CPU: All CPU(s) started at EL2
[ 0.068978] alternatives: patching kernel code
[ 0.071385] devtmpfs: initialized
[ 0.144555] Initilizing CustomIPI irq domain
[ 0.144906] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.158238] pinctrl core: initialized pinctrl subsystem
[ 0.158468] OS set in device tree is L4T.
[ 0.158866] regulator-dummy: no parameters
[ 0.159086] Initializing plugin-manager
[ 0.159155] Plugin module not found
[ 0.160132] node /plugin-manager/fragement@0 match with board >=2180-1000-300
[ 0.160989] node /plugin-manager/fragement@4 match with odm-data l4t
[ 0.161119] Removing Prop nvidia,pmc-wakeup from target /bcmdhd_wlan
[ 0.161637] Adding domain ape-pd to PM domain mc-clk-pd
[ 0.161681] Adding domain adsp-pd to PM domain ape-pd
[ 0.167062] NET: Registered protocol family 16
[ 0.168921] console [pstore-1] enabled
[ 0.168943] pstore: Registered ramoops as persistent store backend
[ 0.168966] ramoops: attached 0x200000@0xb0000000, ecc: 0/0
[ 0.180236] cpuidle: using governor ladder
[ 0.192227] cpuidle: using governor menu
[ 0.192587] bpmp: mail init ok
[ 0.193717] vdso: 2 pages (1 code @ ffffffc0012b1000, 1 data @ ffffffc0012b0000)
[ 0.193775] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.196126] atomic_pool_init():526: DMA: preallocated 1024 KiB pool for atomic allocations
[ 0.197087] tegra_powergate_init: DONE
[ 0.197127] DTS File Name: ../arch/arm64/boot/dts/../../../../../../hardware/nvidia/platform/t210/jetson/kernel-dts/tegra210-jetson-tx1-p2597-2180-a01-devkit.dts
[ 0.197173] DTB Build time: Jan 24 2018 17:36:57
[ 0.198196] Error: Driver ‘tegra-mc’ is already registered, aborting…
[ 0.199908] platform tegra-carveouts: SMMU isn’t ready yet
[ 0.200697] platform tegra-carveouts: domain=ffffffc0fa10f318 allocates as[0]=ffffffc0fa1440a8
[ 0.200768] tegra_smmu 70019000.iommu: Loaded Tegra IOMMU driver
[ 0.201009] platform smmu_test: domain=ffffffc0fa10f618 allocates as[0]=ffffffc0fa144110
[ 0.201346] platform 70016000.bpmp: domain=ffffffc0fa10f918 allocates as[0]=ffffffc0fa144178
[ 0.202073] bpmp: ping status is 0
[ 0.202181] bpmp 70016000.bpmp: firmware tag is 1e4b302fc0f866f97885165cf8b395ac
[ 0.202440] bpmp 70016000.bpmp: probe ok
[ 0.203115] mc: mapped MMIO address: 0xffffff800007e000 → 0x70019000
[ 0.203223] mc: mapped MMIO address: 0xffffff80000b6000 → 0x7001c000
[ 0.203328] mc: mapped MMIO address: 0xffffff80000dc000 → 0x7001d000
[ 0.203418] mc-err: Set intmask: 0x23d40
[ 0.215459] GPIO line 58 (wlan-default-input-h2) hogged as input
[ 0.215508] GPIO line 65 (wlan-default-input-i1) hogged as input
[ 0.215555] GPIO line 56 (wlan-default-output-high-h0) hogged as output/high
[ 0.215596] GPIO line 64 (wlan-default-output-high-i0) hogged as output/high
[ 0.215639] GPIO line 148 (cam0-rst) hogged as output/low
[ 0.215677] GPIO line 151 (cam0-pwdn) hogged as output/low
[ 0.215714] GPIO line 149 (cam1-rst) hogged as output/low
[ 0.215752] GPIO line 152 (cam1-pwdn) hogged as output/low
[ 0.215871] gpiochip_add_data: registered GPIOs 0 to 255 on device: tegra-gpio
[ 0.218462] platform 70006000.serial: domain=ffffffc0fa1a0e18 allocates as[0]=ffffffc0fa1441e0
[ 0.219631] platform sound: domain=ffffffc0fa208718 allocates as[0]=ffffffc0fa144248
[ 0.222171] platform tegradc.0: domain=ffffffc0fa20e918 allocates as[0]=ffffffc0fa1442b0
[ 0.222784] platform tegradc.0: IOVA linear map 0x00000000c6000000(2a000000)
[ 0.223198] platform tegradc.1: domain=ffffffc0fa20ec18 allocates as[0]=ffffffc0fa144318
[ 0.223806] platform tegradc.1: IOVA linear map 0x00000000c6000000(2a000000)
[ 0.226849] platform 57000000.gpu: domain=ffffffc0fa21b118 allocates as[0]=ffffffc0fa144380
[ 0.226928] platform 57000000.gpu: domain=ffffffc0fa21b118 allocates as[1]=ffffffc0fa1443e8
[ 0.227001] platform 57000000.gpu: domain=ffffffc0fa21b118 allocates as[2]=ffffffc0fa144450
[ 0.227069] platform 57000000.gpu: domain=ffffffc0fa21b118 allocates as[3]=ffffffc0fa1444b8
[ 0.227866] tegra-pmc 7000e400.pmc: i2c-thermtrip node not found, emergency thermal reset disabled.
[ 0.227910] tegra-pmc 7000e400.pmc: scratch reg offset dts data not present
[ 0.227934] tegra-pmc: ### PMC reset source: Power on reset
[ 0.227955] tegra-pmc: ### PMC reset status reg: 0x0
[ 0.228338] padctrl padctrl.0: Pad control driver tegra-pmc-padctrl registered
[ 0.228371] tegra-pmc: Clear bootloader IO dpd settings
[ 0.232335] tegra-pmc 7000e400.pmc: PMC: IO pad audio voltage is 1800000
[ 0.236319] tegra-pmc 7000e400.pmc: PMC: IO pad cam voltage is 1800000
[ 0.240317] tegra-pmc 7000e400.pmc: PMC: IO pad dbg voltage is 1800000
[ 0.244317] tegra-pmc 7000e400.pmc: PMC: IO pad dmic voltage is 1800000
[ 0.244346] tegra-pmc 7000e400.pmc: PMC: IO pad pex-ctrl voltage is 1800000
[ 0.248316] tegra-pmc 7000e400.pmc: PMC: IO pad spi voltage is 1800000
[ 0.252317] tegra-pmc 7000e400.pmc: PMC: IO pad uart voltage is 1800000
[ 0.256320] tegra-pmc 7000e400.pmc: PMC: IO pad audio-hv voltage is 1800000
[ 0.256349] tegra-pmc 7000e400.pmc: PMC: IO pad spi-hv voltage is 1800000
[ 0.260317] tegra-pmc 7000e400.pmc: PMC: IO pad gpio voltage is 1800000
[ 0.264315] tegra-pmc 7000e400.pmc: PMC: IO pad sdmmc3 voltage is 1800000
[ 0.264342] tegra-pmc 7000e400.pmc: IO padctrl driver initialized
[ 0.264414] tegra-pmc 7000e400.pmc: PMC: Successfully configure bootrom reset commands
[ 0.267608] platform 1003000.pcie-controller: domain=ffffffc0fa2c8218 allocates as[0]=ffffffc0fa144520
[ 0.269990] platform sdhci-tegra.3: domain=ffffffc0fa2cf318 allocates as[0]=ffffffc0fa144588
[ 0.270617] platform sdhci-tegra.0: domain=ffffffc0fa2cf718 allocates as[0]=ffffffc0fa1445f0
[ 0.276287] vdd-ac-bat: 5000 mV
[ 0.277527] vdd-cpu-fixed: 1000 mV
[ 0.281465] irq: no irq domain found for /soctherm@0x700E2000 !
[ 0.281819] irq: no irq domain found for /soctherm@0x700E2000 !
[ 0.305439] ACPI: Interpreter disabled.
[ 0.306284] SCSI subsystem initialized
[ 0.306586] usbcore: registered new interface driver usbfs
[ 0.306664] usbcore: registered new interface driver hub
[ 0.306770] usbcore: registered new device driver usb
[ 0.310105] gpiochip_add_data: registered GPIOs 496 to 511 on device: tca9539
[ 0.311598] gpiochip_add_data: registered GPIOs 480 to 495 on device: tca9539
[ 0.314730] max77620 4-003c: PMIC Version OTP:0x3C and ES:0x8
[ 0.316521] GPIO line 474 (spmic-default-output-high) hogged as output/high
[ 0.316643] gpiochip_add_data: registered GPIOs 472 to 479 on device: max77620-gpio
[ 0.320352] vdd-core: 600 ↔ 1400 mV at 1125 mV
[ 0.324344] vddio-ddr: at 1125 mV
[ 0.325208] vdd-pre-reg: 1350 mV
[ 0.328221] vdd-1v8: 1800 mV
[ 0.332221] avdd-sys: 1200 mV
[ 0.336221] vdd-pex: 1050 mV
[ 0.336821] vddio-sdmmc1: 1800 ↔ 3300 mV at 3300 mV
[ 0.337650] vdd-cam-hv: 2800 mV
[ 0.340221] vdd-rtc: 850 mV
[ 0.341055] avdd-ts-hv: 3300 mV
[ 0.341906] vdd-ts: 1800 mV
[ 0.344222] vdd-gen-pll-edp: 1050 mV
[ 0.348221] vdd-hdmi-dp: 1050 mV
[ 0.348874] max77620 4-003c: max77620 probe successful
[ 0.350858] media: Linux media interface: v0.10
[ 0.350932] Linux video capture interface: v2.00
[ 0.358646] tegra210-emc 7001b000.memory-controller: validated EMC DFS table
[ 0.358997] Advanced Linux Sound Architecture Driver Initialized.
[ 0.362313] tegra210_dvfs: no clock found for sdmmc2_ddr
[ 0.362361] tegra210_dvfs: no clock found for sdmmc4_ddr
[ 0.362440] tegra210_dvfs: no clock found for sdmmc1_ddr
[ 0.362478] tegra210_dvfs: no clock found for sdmmc3_ddr
[ 0.365444] regulator_get() failed for (dvfs,vdd-cpu), -19
[ 0.365472] tegra_dvfs: Unable to get vdd-cpu rail for step info, defering probe
[ 0.368227] vdd-3v3: 3300 mV
[ 0.372221] max77620-gpio7: 1050 mV
[ 0.372556] lcd-bl-en: 1800 mV
[ 0.372859] en-vdd-sd: 3300 mV
[ 0.373542] en-vdd-cam: 1800 mV
[ 0.376221] vdd-sys-boost: 5000 mV
[ 0.376915] vdd-hdmi: 5000 mV
[ 0.377168] aux-3v3: 3300 mV
[ 0.377404] snsr_pm: 3300 mV
[ 0.380222] vdd-disp-3v0: 3000 mV
[ 0.380912] vdd-fan: 5000 mV
[ 0.381202] usb-vbus1: 5000 mV
[ 0.381879] en-vdd-ts-1v8: 1800 mV
[ 0.382546] en-vdd-ts-hv-3v3: 3300 mV
[ 0.383393] en-vdd-disp-3v3: 3300 mV
[ 0.384050] en-mdm-pwr-3v7: 3700 mV
[ 0.384922] en-vdd-disp-1v8: 1800 mV
[ 0.385602] en-vdd-cam-hv-2v8: 2800 mV
[ 0.385900] rtl-5v0: 5000 mV
[ 0.386190] en-usb-vbus2: 5000 mV
[ 0.386851] en-vdd-cam-1v2: 1200 mV
[ 0.387144] en-vdd-vcm-2v8: 2800 mV
[ 0.389949] extcon-gpio-states extcon:extcon@1: Cable state 2
[ 0.391340] clocksource: Switched to clocksource arch_sys_counter
[ 0.431010] nvmap_heap_init: nvmap_heap_init: created heap block cache
[ 0.431427] dma_declare_coherent_resizable_cma_memory:290: resizable heap=vpr, base=0x00000000c6000000, size=0x2a000000
[ 0.431614] cma: enabled page replacement for spfn=c6000, epfn=f0000
[ 0.431641] dma_declare_coherent_resizable_cma_memory:337: resizable cma heap=vpr create successful
[ 0.431672] tegra-carveouts tegra-carveouts: assigned reserved memory node vpr-carveout
[ 0.431732] tegra-carveouts tegra-carveouts: iram :dma coherent mem declare 0x0000000040001000,258048
[ 0.431769] tegra-carveouts tegra-carveouts: assigned reserved memory node iram-carveout
[ 0.432086] misc nvmap: created heap iram base 0x0000000040001000 size (252KiB)
[ 0.432800] misc nvmap: created heap vpr base 0x00000000c6000000 size (688128KiB)
[ 0.433555] pnp: PnP ACPI: disabled
[ 0.445477] thermal thermal_zone0: Registering thermal zone thermal_zone0 for type AO-therm
[ 0.447397] thermal thermal_zone1: Registering thermal zone thermal_zone1 for type CPU-therm
[ 0.447822] thermal thermal_zone2: Registering thermal zone thermal_zone2 for type GPU-therm
[ 0.448023] thermal thermal_zone3: Registering thermal zone thermal_zone3 for type PLL-therm
[ 0.449667] thermal thermal_zone4: Registering thermal zone thermal_zone4 for type Tdiode_tegra
[ 0.449929] thermal thermal_zone5: Registering thermal zone thermal_zone5 for type PMIC-Die
[ 0.450161] thermal thermal_zone6: Registering thermal zone thermal_zone6 for type Tboard_tegra
[ 0.451312] isomgr_init(): iso emc max clk=1600000KHz
[ 0.451391] isomgr_init(): max_iso_bw=11520000KB
[ 0.451533] NET: Registered protocol family 2
[ 0.452097] TCP established hash table entries: 32768 (order: 6, 262144 bytes)
[ 0.452282] TCP bind hash table entries: 32768 (order: 7, 524288 bytes)
[ 0.452554] TCP: Hash tables configured (established 32768 bind 32768)
[ 0.452655] UDP hash table entries: 2048 (order: 4, 65536 bytes)
[ 0.452718] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes)
[ 0.452959] NET: Registered protocol family 1
[ 0.453276] RPC: Registered named UNIX socket transport module.
[ 0.453303] RPC: Registered udp transport module.
[ 0.453324] RPC: Registered tcp transport module.
[ 0.453344] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.453604] Trying to unpack rootfs image as initramfs…
[ 0.464962] host1x 50000000.host1x: initialized
[ 0.466702] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[ 0.470061] futex hash table entries: 1024 (order: 5, 131072 bytes)
[ 0.470185] audit: initializing netlink subsys (disabled)
[ 0.470243] audit: type=2000 audit(0.463:1): initialized
[ 0.482320] ntfs: driver 2.1.32 [Flags: R/O].
[ 0.482810] fuse init (API version 7.23)
[ 0.485449] io scheduler noop registered (default)
[ 0.485481] io scheduler deadline registered
[ 0.485796] io scheduler cfq registered
[ 0.491363] tegra21x-padctl-uphy 7009f000.pinctrl: padctl mmio start 0x000000007009f000 end 0x000000007009ffff
[ 0.491410] tegra21x-padctl-uphy 7009f000.pinctrl: TEGRA_FUSE_SKU_CALIB_0 0x81ea412
[ 0.491445] tegra21x-padctl-uphy 7009f000.pinctrl: TEGRA_FUSE_USB_CALIB_EXT_0 0x4
[ 0.492932] tegra21x-padctl-uphy 7009f000.pinctrl: UTMI-0 is used by XUSB
[ 0.492966] tegra21x-padctl-uphy 7009f000.pinctrl: using UTMI port 0 for otg
[ 0.492994] tegra21x-padctl-uphy 7009f000.pinctrl: UTMI-2 is used by XUSB
[ 0.493032] tegra21x-padctl-uphy 7009f000.pinctrl: uphy_lane = 5, set usb3_lanes = 0x20
[ 0.493076] tegra21x-padctl-uphy 7009f000.pinctrl: USB3 port 1 maps to USB2 port 2
[ 0.493110] tegra21x-padctl-uphy 7009f000.pinctrl: UTMI-1 is used by XUSB
[ 0.493144] tegra21x-padctl-uphy 7009f000.pinctrl: uphy_lane = 6, set usb3_lanes = 0x60
[ 0.493185] tegra21x-padctl-uphy 7009f000.pinctrl: USB3 port 0 maps to USB2 port 1
[ 0.493230] tegra21x-padctl-uphy 7009f000.pinctrl: uphy_lane = 1, set pcie_lanes = 0x2
[ 0.493277] tegra21x-padctl-uphy 7009f000.pinctrl: uphy_lane = 2, set pcie_lanes = 0x6
[ 0.493324] tegra21x-padctl-uphy 7009f000.pinctrl: uphy_lane = 3, set pcie_lanes = 0xe
[ 0.493370] tegra21x-padctl-uphy 7009f000.pinctrl: uphy_lane = 4, set pcie_lanes = 0x1e
[ 0.493416] tegra21x-padctl-uphy 7009f000.pinctrl: uphy_lane = 0, set pcie_lanes = 0x1f
[ 0.493464] tegra21x-padctl-uphy 7009f000.pinctrl: uphy_lane = 7, set sata_lanes = 0x80
[ 0.493917] tegra21x-padctl-uphy 7009f000.pinctrl: mailbox is not ready yet
[ 0.494973] tegra-pwm 7000a000.pwm: PWM clk can sleep in ops
[ 0.496116] tegra-dfll-pwm 70110000.pwm: DFLL pwm-rate: 12800000
[ 0.496886] Adding domain pcie-pd to PM domain mc-clk-pd
[ 0.501663] tegra-pcie 1003000.pcie-controller: 4x1, 1x1 configuration
[ 0.501733] tegra-pcie 1003000.pcie-controller: failed to get PHY: -517
[ 0.501759] tegra-pcie 1003000.pcie-controller: failed to get PHYs: -517
[ 0.505419] tsec 54500000.tsec: initialized
[ 0.506762] tsec 54100000.tsecb: initialized
[ 0.509787] nvdec 54480000.nvdec: initialized
[ 0.515092] falcon 54340000.vic: initialized
[ 0.517019] falcon 544c0000.nvenc: initialized
[ 0.518203] falcon 54380000.nvjpg: initialized
[ 0.520271] DC OR NODE connected to /host1x/sor
[ 0.520296]
[ 0.520296] Tonie’s Msg : parse_dc_out_type id : 0
[ 0.520366]
[ 0.520366] tegra_primary_panel_get_dt_node /host1x/sor 0
[ 0.520400]
[ 0.520400] tegra_primary_panel_get_dt_node /host1x/sor 2
[ 0.520479] display board info: id 0xffff, fab 0x0
[ 0.520729] tegra_primary_panel_get_dt_node np_sor:sor np_panel:panel-a-edp-1080p-14-0
[ 0.520762] Tonie’s Msg : parse_dc_out_type out_type : 3
[ 0.520807]
[ 0.520807] Tonie’s Msg : of_dc_parse_platform_data dc_or_node_name /host1x/sor
[ 0.520857]
[ 0.520857] Tonie’s Msg : parse_dp_settings id : 0
[ 0.520916]
[ 0.520916] tegra_primary_panel_get_dt_node /host1x/sor 0
[ 0.520947]
[ 0.520947] tegra_primary_panel_get_dt_node /host1x/sor 2
[ 0.520976] display board info: id 0xffff, fab 0x0
[ 0.521197] tegra_primary_panel_get_dt_node np_sor:sor np_panel:panel-a-edp-1080p-14-0
[ 0.521249] parse_dp_settings: No lt-data node. Using default setting.
[ 0.521422] tegradc tegradc.0: DT parsed successfully
[ 0.521479] tegradc tegradc.0: Display dc.ffffff8000980000 registered with id=0
[ 0.521770]
[ 0.521770] Tonie’s Msg : tegra_get_panel_node_out_type_check id : 0
[ 0.521833]
[ 0.521833] tegra_primary_panel_get_dt_node /host1x/sor 0
[ 0.521865]
[ 0.521865] tegra_primary_panel_get_dt_node /host1x/sor 2
[ 0.521894] display board info: id 0xffff, fab 0x0
[ 0.522132] tegra_primary_panel_get_dt_node np_sor:sor np_panel:panel-a-edp-1080p-14-0
[ 0.522168]
[ 0.522168] Tonie’s Msg : sor_num = 0
[ 0.522964] tegradc tegradc.0: _tegra_dc_set_mode():MODE:720x480@82.220Hz pclk=37037000
[ 0.523756] tegradc tegradc.0: Tonie’s Msg : tegra_dc_probe.
[ 0.524037] tegradc tegradc.0: probed
[ 0.527815] tegra_camera_platform tegra-camera-platform: tegra_camera_probe:camera_platform_driver probe
[ 0.528040] misc tegra_camera_ctrl: tegra_camera_isomgr_register isp_iso_bw=1020000, vi_iso_bw=750000, max_bw=1020000
[ 0.532437] tegra-apbdma 60020000.dma: Tegra20 APB DMA driver register 32 channels
[ 0.534534] tegra-adma 702e2000.adma: Tegra ADMA driver register 10 channels
[ 0.536194] tegra-fuse-burn 7000f800.efuse:efuse-burn: Fuse burn driver initialized
[ 0.536522] kfuse 7000fc00.kfuse: initialized
[ 0.538604] tegra-pmc-iopower pmc-iopower: NO_IOPOWER setting 0x0
[ 0.539684] clk_cbus_round_rate: no gbus parent
[ 0.539715] tegra_gpu_edp gpu_edp: unable to get max GPU freq
[ 0.540289] tegra-dfll-pwm 70110000.pwm: DFLL_PWM regulator is available now
[ 0.540323] vdd-cpu: 708 ↔ 1322 mV at 708 mV
[ 0.540390] pwm-regulator pwm_regulators:pwm-regulator@0: PWM regulator registration passed
[ 0.541638] vdd-gpu: applied init 1000000uV constraint
[ 0.541669] vdd-gpu: 710 ↔ 1320 mV at 1000 mV
[ 0.541732] pwm-regulator pwm_regulators:pwm-regulator@1: PWM regulator registration passed
[ 0.542144] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[ 0.542296] No Device Node present for smmu client: serial8250 !!
[ 0.542325] platform serial8250: No iommus property found in DT node, got swgids from fixup(101004000)
[ 0.542363] No Device Node present for smmu client: serial8250 !!
[ 0.542388] platform serial8250: No iommus property found in DT node, got swgids from fixup(101004000)
[ 0.543533] No Device Node present for smmu client: serial8250 !!
[ 0.543564] serial8250 serial8250: No iommus property found in DT node, got swgids from fixup(101004000)
[ 0.543612] No Device Node present for smmu client: serial8250 !!
[ 0.543638] serial8250 serial8250: No iommus property found in DT node, got swgids from fixup(101004000)
[ 0.544341] console [ttyS0] disabled
[ 0.544415] 70006000.serial: ttyS0 at MMIO 0x70006000 (irq = 320, base_baud = 25500000) is a Tegra
[ 2.688728] console [ttyS0] enabled
[ 2.690099] 70006040.serial: ttyTHS1 at MMIO 0x70006040 (irq = 321, base_baud = 0) is a TEGRA_UART
[ 2.690569] 70006200.serial: ttyTHS2 at MMIO 0x70006200 (irq = 322, base_baud = 0) is a TEGRA_UART
[ 2.690914] serial-tegra 70006300.serial: RX in PIO mode
[ 2.691019] 70006300.serial: ttyTHS3 at MMIO 0x70006300 (irq = 323, base_baud = 0) is a TEGRA_UART
[ 2.693114] Console: switching to colour frame buffer device 90x30
[ 2.697474] gk20a 57000000.gpu: platform probe failed
[ 2.704215] brd: module loaded
[ 2.775520] tegradc tegradc.0: fb registered
[ 2.782885] loop: module loaded
[ 2.785388]
[ 2.785388] Tonie’s Msg : prod_string prod_c_dpaux_dp
[ 2.800315] zram: Added device: zram0
[ 2.806278] Silicon Labs C2 port support v. 0.51.0 - (C) 2007 Rodolfo Giometti
[ 2.816008] nct1008_nct72 0-004c: find device tree node, parsing dt
[ 2.824599] nct1008_nct72 0-004c: starting parse dt
[ 2.831801] nct1008_nct72 0-004c: success parsing dt
[ 2.839138] nct1008_nct72 0-004c: success in enabling tmp451 VDD rail
[ 2.882613] tmp451: Enabled overheat logging at 102.00C
[ 2.890164] nct1008_nct72 0-004c: nct1008_probe: initialized
[ 2.900783] THERMAL EST: found 2 subdevs
[ 2.906824] THERMAL EST num_resources: 0
[ 2.912824] [THERMAL EST subdev 0]
[ 2.918230] [THERMAL EST subdev 1]
[ 2.923868] thermal thermal_zone7: Registering thermal zone thermal_zone7 for type thermal-fan-est
[ 2.936602] THERMAL EST: thz register success.
[ 2.943069] THERMAL EST: end of probe, return err: 0
[ 2.949947] tegra_profiler: Branch: Dev
[ 2.955536] tegra_profiler: Version: 1.109
[ 2.961317] tegra_profiler: Samples version: 37
[ 2.967495] tegra_profiler: IO version: 21
[ 2.973202] armv8_pmu: imp: 0x41, idcode: 0x1
[ 2.979170] armv8_pmu: [0] arch: AA64 PmuV3 ARM CORTEX-A57, type: 5, ver: 0
[ 2.987816] armv8_pmu: imp: 0x41, idcode: 0x1
[ 2.993857] armv8_pmu: [1] arch: AA64 PmuV3 ARM CORTEX-A57, type: 5, ver: 0
[ 3.002567] armv8_pmu: imp: 0x41, idcode: 0x1
[ 3.008648] armv8_pmu: [2] arch: AA64 PmuV3 ARM CORTEX-A57, type: 5, ver: 0
[ 3.017356] armv8_pmu: imp: 0x41, idcode: 0x1
[ 3.019426]
[ 3.019426] Tonie’s Msg : clock caculation div=2, out=3, rate=37036669
[ 3.021640] tegradc tegradc.0: Tonie’s Msg : tegra_dc_init
[ 3.021689] tegradc tegradc.0: tegra_dc_program_mode():MODE:720x480@82.220Hz pclk=37037000
[ 3.021713]
[ 3.021713] Tonie’s Msg : clock caculation div=2, out=3, rate=37036669
[ 3.021722] tegradc tegradc.0: nominal-pclk:37037000 parent:37036669 div:1.0 pclk:37036669 36666630~40370330
[ 3.021805] tegradc tegradc.0: Tonie’s Msg : edp: tegra_dc_dp_enable 0
[ 3.021811] tegradc tegradc.0: Tonie’s Msg dp: tegra_dc_dp_dpcd_write
[ 3.022062] tegradc tegradc.0: Tonie’s Msg dp: tegra_dc_dp_i2c_write
[ 3.026059] tegradc tegradc.0: _tegra_dc_set_mode():MODE:3840x1200@60.003Hz pclk=295246000
[ 3.026159]
[ 3.026159] Tonie’s Msg : clock caculation div=2, out=3, rate=295243359
[ 3.026165] tegradc tegradc.0: Tonie’s Msg : dp: tegra_dp_dpcd_init
[ 3.026980] tegradc tegradc.0: Tonie’s Msg dp: tegra_dc_dpaux_write
[ 3.027206] tegradc tegradc.0: dp: aux write retry (0x10010000) – 1
[ 3.028246] tegradc tegradc.0: dp: aux write retry (0x10010000) – 0
[ 3.029277] tegradc tegradc.0: dp: aux write got error (0x10010000)
[ 3.029282] tegradc tegradc.0: Tonie’s Msg : edp: tegra_dc_dp_enable 111
[ 3.029286]
[ 3.029286] Tonie’s Msg : tegra_dc_sor_enable_dp sor->dc->initialized 0
[ 3.032297]
[ 3.032297] Tonie’s Msg : tegra_sor_dp_cal
[ 3.032315] tegradc tegradc.0: Tonie’s Msg : dp: tegra_sor_config_dp_prods prod_c_dp err=0
[ 3.034613] tegradc tegradc.0: Tonie’s Msg dp: tegra_dc_dp_dpcd_write
[ 3.035123] tegradc tegradc.0: Tonie’s Msg dp: tegra_dc_dp_dpcd_write
[ 3.035660] tegradc tegradc.0: Tonie’s Msg dp: tegra_dc_dp_dpcd_write
[ 3.036066] tegradc tegradc.0: Tonie’s Msg dp: tegra_dc_dp_dpcd_write
[ 3.036289] tegradc tegradc.0: Tonie’s Msg dp: tegra_dc_dp_dpcd_write
[ 3.036907]
[ 3.036907] Tonie’s Msg : clock caculation div=2, out=3, rate=295243359
[ 3.036933] dp lt: state 0 (Reset), hpd 1, pending_lt_evt 1
[ 3.036937] dp lt: switching from state 0 (Reset) to state 0 (Reset)
[ 3.036945] dp lt: state 0 (Reset), hpd 1, pending_lt_evt 0
[ 3.037255] tegradc tegradc.0: Tonie’s Msg dp: tegra_dc_dp_dpcd_write
[ 3.037775] tegradc tegradc.0: Tonie’s Msg dp: tegra_dc_dp_dpcd_write
[ 3.038119] dp lt: switching from state 0 (Reset) to state 2 (clock recovery)
[ 3.038127] dp lt: state 2 (clock recovery), hpd 1, pending_lt_evt 0
[ 3.038133] tegradc tegradc.0: Tonie’s Msg dp: tegra_dc_dp_dpcd_write
[ 3.038349] sor0 dp lt: config: lane 0: vs level: 0, pe level: 0, pc2 level: 0
[ 3.038357] sor0 dp lt: config: lane 1: vs level: 0, pe level: 0, pc2 level: 0
[ 3.038366] sor0 dp lt: config: lane 2: vs level: 0, pe level: 0, pc2 level: 0
[ 3.038374] sor0 dp lt: config: lane 3: vs level: 0, pe level: 0, pc2 level: 0
[ 3.038421] tegradc tegradc.0: Tonie’s Msg dp: tegra_dc_dpaux_write
[ 3.039406] dp lt: CR done
[ 3.039411] dp lt: switching from state 2 (clock recovery) to state 3 (channel equalization)
[ 3.039419] dp lt: state 3 (channel equalization), hpd 1, pending_lt_evt 0
[ 3.039422] Tonie’s Msg : lt: lt_data->tps3_supported 0
[ 3.039427] tegradc tegradc.0: Tonie’s Msg dp: tegra_dc_dp_dpcd_write
[ 3.040758] Tonie’s Msg : lt: get_channel_eq_status n_lanes 4
[ 3.041063] Tonie’s Msg : lt: read dpcd[0] status 119
[ 3.041366] Tonie’s Msg : lt: read dpcd[1] status 119
[ 3.041672] tegradc tegradc.0: Tonie’s Msg dp: tegra_dc_dp_dpcd_write
[ 3.042145] dp lt: CE done
[ 3.042150] dp lt: switching from state 3 (channel equalization) to state 5 (link training pass)
[ 3.042598] DC OR NODE connected to /host1x/sor1
[ 3.042601]
[ 3.042601] Tonie’s Msg : parse_dc_out_type id : 1
[ 3.042604]
[ 3.042604] tegra_secondary_panel_get_dt_node /host1x/sor1 0
[ 3.042652] tegra_secondary_panel_get_dt_node np_sor sor1 np_panel hdmi-display
[ 3.042655]
[ 3.042655] tegra_secondary_panel_get_dt_node /host1x/sor1 success
[ 3.042661] Tonie’s Msg : parse_dc_out_type out_type : 3
[ 3.042685]
[ 3.042685] Tonie’s Msg : of_dc_parse_platform_data dc_or_node_name /host1x/sor1
[ 3.042690]
[ 3.042690] Tonie’s Msg : parse_dp_settings id : 1
[ 3.042692]
[ 3.042692] tegra_secondary_panel_get_dt_node /host1x/sor1 0
[ 3.042721] tegra_secondary_panel_get_dt_node np_sor sor1 np_panel hdmi-display
[ 3.042723]
[ 3.042723] tegra_secondary_panel_get_dt_node /host1x/sor1 success
[ 3.042753] parse_dp_settings: No lt-data node. Using default setting.
[ 3.042865] tegradc tegradc.1: DT parsed successfully
[ 3.042907] tegradc tegradc.1: Display dc.ffffff8007400000 registered with id=1
[ 3.043730] tegradc tegradc.0: Tonie’s Msg : tegra_dc_update_mode mode_dirty 1
[ 3.043776] tegradc tegradc.0: tegra_dc_program_mode():MODE:3840x1200@60.003Hz pclk=295246000
[ 3.044391]
[ 3.044391] Tonie’s Msg : tegra_get_panel_node_out_type_check id : 1
[ 3.044394]
[ 3.044394] tegra_secondary_panel_get_dt_node /host1x/sor1 0
[ 3.044427] tegra_secondary_panel_get_dt_node np_sor sor1 np_panel hdmi-display
[ 3.044429]
[ 3.044429] tegra_secondary_panel_get_dt_node /host1x/sor1 success
[ 3.044438]
[ 3.044438] Tonie’s Msg : sor_num = 1
[ 3.045095]
[ 3.045095] Tonie’s Msg : clock caculation div=2, out=3, rate=295243359
[ 3.045105] tegradc tegradc.0: nominal-pclk:295246000 parent:295243359 div:1.0 pclk:295243359 292293540~321818140
[ 3.045276] tegradc tegradc.0: Tonie’s Msg : tegra_dc_update_mode mode_dirty 0
[ 3.048722] tegradc tegradc.1: _tegra_dc_set_mode():MODE:720x480@82.220Hz pclk=37037000
[ 3.049742] tegradc tegradc.1: Tonie’s Msg : tegra_dc_probe.
[ 3.050078] tegradc tegradc.1: probed
[ 3.052324] tegradc tegradc.0: Tonie’s Msg : tegra_dc_update_mode mode_dirty 0
[ 3.083104] tegradc tegradc.0: dp: unplug event received
[ 3.227918] tegradc tegradc.0: dp: plug event received
[ 3.752178] armv8_pmu: [3] arch: AA64 PmuV3 ARM CORTEX-A57, type: 5, ver: 0
[ 3.752579] tegra_profiler: auth: init
[ 3.753728] tegra-ahci 70027000.sata: Missing devslp-active state
[ 3.761664] Rounding down aligned max_sectors from 4294967295 to 4294967288
[ 3.776064] spi-tegra114 7000d400.spi: Static pin configuration used
[ 3.793091] tegradc tegradc.1: fb registered
[ 3.793444] spi-tegra114 7000da00.spi: Static pin configuration used
[ 3.809103] tun: Universal TUN/TAP device driver, 1.6
[ 3.810996]
[ 3.810996] Tonie’s Msg : prod_string prod_c_dpaux_dp
[ 3.812162]
[ 3.812162] Tonie’s Msg : clock caculation div=2, out=3, rate=37036523
[ 3.813885] tegradc tegradc.1: Tonie’s Msg : tegra_dc_init
[ 3.813942] tegradc tegradc.1: tegra_dc_program_mode():MODE:720x480@82.220Hz pclk=37037000
[ 3.813970]
[ 3.813970] Tonie’s Msg : clock caculation div=2, out=3, rate=37036523
[ 3.813978] tegradc tegradc.1: nominal-pclk:37037000 parent:37036523 div:1.0 pclk:37036523 36666630~40370330
[ 3.814034] tegradc tegradc.1: Tonie’s Msg : edp: tegra_dc_dp_enable 0
[ 3.814041] tegradc tegradc.1: Tonie’s Msg dp: tegra_dc_dp_dpcd_write
[ 3.814347] tegradc tegradc.1: Tonie’s Msg dp: tegra_dc_dp_i2c_write
[ 3.818347] tegradc tegradc.1: _tegra_dc_set_mode():MODE:3840x1200@60.003Hz pclk=295246000
[ 3.818454]
[ 3.818454] Tonie’s Msg : clock caculation div=2, out=3, rate=295243750
[ 3.818460] tegradc tegradc.1: Tonie’s Msg : dp: tegra_dp_dpcd_init
[ 3.819262] tegradc tegradc.1: Tonie’s Msg dp: tegra_dc_dpaux_write
[ 3.819489] tegradc tegradc.1: dp: aux write retry (0x10010000) – 1
[ 3.820518] tegradc tegradc.1: dp: aux write retry (0x10010000) – 0
[ 3.821543] tegradc tegradc.1: dp: aux write got error (0x10010000)
[ 3.821549] tegradc tegradc.1: Tonie’s Msg : edp: tegra_dc_dp_enable 111
[ 3.821554]
[ 3.821554] Tonie’s Msg : tegra_dc_sor_enable_dp sor->dc->initialized 0
[ 3.824567]
[ 3.824567] Tonie’s Msg : tegra_sor_dp_cal
[ 3.824590] tegradc tegradc.1: Tonie’s Msg : dp: tegra_sor_config_dp_prods prod_c_dp err=0
[ 3.826915] tegradc tegradc.1: Tonie’s Msg dp: tegra_dc_dp_dpcd_write
[ 3.827427] tegradc tegradc.1: Tonie’s Msg dp: tegra_dc_dp_dpcd_write
[ 3.827955] tegradc tegradc.1: Tonie’s Msg dp: tegra_dc_dp_dpcd_write
[ 3.828360] tegradc tegradc.1: Tonie’s Msg dp: tegra_dc_dp_dpcd_write
[ 3.828589] tegradc tegradc.1: Tonie’s Msg dp: tegra_dc_dp_dpcd_write
[ 3.829143]
[ 3.829143] Tonie’s Msg : clock caculation div=2, out=3, rate=295243750
[ 3.829170] dp lt: state 0 (Reset), hpd 1, pending_lt_evt 1
[ 3.829175] dp lt: switching from state 0 (Reset) to state 0 (Reset)
[ 3.829182] dp lt: state 0 (Reset), hpd 1, pending_lt_evt 0
[ 3.829496] tegradc tegradc.1: Tonie’s Msg dp: tegra_dc_dp_dpcd_write
[ 3.830015] tegradc tegradc.1: Tonie’s Msg dp: tegra_dc_dp_dpcd_write
[ 3.830364] dp lt: switching from state 0 (Reset) to state 2 (clock recovery)
[ 3.830372] dp lt: state 2 (clock recovery), hpd 1, pending_lt_evt 0
[ 3.830378] tegradc tegradc.1: Tonie’s Msg dp: tegra_dc_dp_dpcd_write
[ 3.830597] sor1 dp lt: config: lane 0: vs level: 0, pe level: 0, pc2 level: 0
[ 3.830607] sor1 dp lt: config: lane 1: vs level: 0, pe level: 0, pc2 level: 0
[ 3.830616] sor1 dp lt: config: lane 2: vs level: 0, pe level: 0, pc2 level: 0
[ 3.830624] sor1 dp lt: config: lane 3: vs level: 0, pe level: 0, pc2 level: 0
[ 3.830671] tegradc tegradc.1: Tonie’s Msg dp: tegra_dc_dpaux_write
[ 3.831655] dp lt: CR done
[ 3.831661] dp lt: switching from state 2 (clock recovery) to state 3 (channel equalization)
[ 3.831669] dp lt: state 3 (channel equalization), hpd 1, pending_lt_evt 0
[ 3.831672] Tonie’s Msg : lt: lt_data->tps3_supported 0
[ 3.831677] tegradc tegradc.1: Tonie’s Msg dp: tegra_dc_dp_dpcd_write
[ 3.832964] Tonie’s Msg : lt: get_channel_eq_status n_lanes 4
[ 3.833246] Tonie’s Msg : lt: read dpcd[0] status 17
[ 3.833250] dp lt: CE not done
[ 3.833815] dp lt: new config: lane 0: vs level: 0, pe level: 0, pc2 level: 0
[ 3.833819] dp lt: new config: lane 1: vs level: 0, pe level: 0, pc2 level: 0
[ 3.833822] dp lt: new config: lane 2: vs level: 0, pe level: 0, pc2 level: 0
[ 3.833826] dp lt: new config: lane 3: vs level: 0, pe level: 0, pc2 level: 0
[ 3.833835] sor1 dp lt: config: lane 0: vs level: 0, pe level: 0, pc2 level: 0
[ 3.833843] sor1 dp lt: config: lane 1: vs level: 0, pe level: 0, pc2 level: 0
[ 3.833852] sor1 dp lt: config: lane 2: vs level: 0, pe level: 0, pc2 level: 0
[ 3.833860] sor1 dp lt: config: lane 3: vs level: 0, pe level: 0, pc2 level: 0
[ 3.833906] tegradc tegradc.1: Tonie’s Msg dp: tegra_dc_dpaux_write
[ 3.834142] dp lt: CE retry
[ 3.834148] dp lt: switching from state 3 (channel equalization) to state 3 (channel equalization)
[ 3.834155] dp lt: state 3 (channel equalization), hpd 1, pending_lt_evt 0
[ 3.834158] Tonie’s Msg : lt: lt_data->tps3_supported 0
[ 3.835234] Tonie’s Msg : lt: get_channel_eq_status n_lanes 4
[ 3.835519] Tonie’s Msg : lt: read dpcd[0] status 17
[ 3.835521] dp lt: CE not done
[ 3.836086] dp lt: new config: lane 0: vs level: 0, pe level: 0, pc2 level: 0
[ 3.836090] dp lt: new config: lane 1: vs level: 0, pe level: 0, pc2 level: 0
[ 3.836094] dp lt: new config: lane 2: vs level: 0, pe level: 0, pc2 level: 0
[ 3.836097] dp lt: new config: lane 3: vs level: 0, pe level: 0, pc2 level: 0
[ 3.836106] sor1 dp lt: config: lane 0: vs level: 0, pe level: 0, pc2 level: 0
[ 3.836114] sor1 dp lt: config: lane 1: vs level: 0, pe level: 0, pc2 level: 0
[ 3.836123] sor1 dp lt: config: lane 2: vs level: 0, pe level: 0, pc2 level: 0
[ 3.836131] sor1 dp lt: config: lane 3: vs level: 0, pe level: 0, pc2 level: 0
[ 3.836177] tegradc tegradc.1: Tonie’s Msg dp: tegra_dc_dpaux_write
[ 3.836412] dp lt: CE retry
[ 3.836417] dp lt: switching from state 3 (channel equalization) to state 3 (channel equalization)
[ 3.836425] dp lt: state 3 (channel equalization), hpd 1, pending_lt_evt 0
[ 3.836428] Tonie’s Msg : lt: lt_data->tps3_supported 0
[ 3.837502] Tonie’s Msg : lt: get_channel_eq_status n_lanes 4
[ 3.837784] Tonie’s Msg : lt: read dpcd[0] status 17
[ 3.837786] dp lt: CE not done
[ 3.838361] dp lt: new config: lane 0: vs level: 0, pe level: 3, pc2 level: 0
[ 3.838365] dp lt: new config: lane 1: vs level: 0, pe level: 3, pc2 level: 0
[ 3.838368] dp lt: new config: lane 2: vs level: 0, pe level: 3, pc2 level: 0
[ 3.838371] dp lt: new config: lane 3: vs level: 0, pe level: 3, pc2 level: 0
[ 3.838380] sor1 dp lt: config: lane 0: vs level: 0, pe level: 3, pc2 level: 0
[ 3.838389] sor1 dp lt: config: lane 1: vs level: 0, pe level: 3, pc2 level: 0
[ 3.838397] sor1 dp lt: config: lane 2: vs level: 0, pe level: 3, pc2 level: 0
[ 3.838406] sor1 dp lt: config: lane 3: vs level: 0, pe level: 3, pc2 level: 0
[ 3.838451] tegradc tegradc.1: Tonie’s Msg dp: tegra_dc_dpaux_write
[ 3.838688] dp lt: CE retry
[ 3.838693] dp lt: switching from state 3 (channel equalization) to state 3 (channel equalization)
[ 3.838700] dp lt: state 3 (channel equalization), hpd 1, pending_lt_evt 0
[ 3.838703] Tonie’s Msg : lt: lt_data->tps3_supported 0
[ 3.839783] Tonie’s Msg : lt: get_channel_eq_status n_lanes 4
[ 3.840065] Tonie’s Msg : lt: read dpcd[0] status 17
[ 3.840067] dp lt: CE not done
[ 3.840639] dp lt: new config: lane 0: vs level: 0, pe level: 2, pc2 level: 0
[ 3.840642] dp lt: new config: lane 1: vs level: 0, pe level: 2, pc2 level: 0
[ 3.840646] dp lt: new config: lane 2: vs level: 0, pe level: 2, pc2 level: 0
[ 3.840649] dp lt: new config: lane 3: vs level: 0, pe level: 2, pc2 level: 0
[ 3.840658] sor1 dp lt: config: lane 0: vs level: 0, pe level: 2, pc2 level: 0
[ 3.840667] sor1 dp lt: config: lane 1: vs level: 0, pe level: 2, pc2 level: 0
[ 3.840675] sor1 dp lt: config: lane 2: vs level: 0, pe level: 2, pc2 level: 0
[ 3.840683] sor1 dp lt: config: lane 3: vs level: 0, pe level: 2, pc2 level: 0
[ 3.840730] tegradc tegradc.1: Tonie’s Msg dp: tegra_dc_dpaux_write
[ 3.840966] dp lt: CE retry
[ 3.840970] dp lt: switching from state 3 (channel equalization) to state 3 (channel equalization)
[ 3.840977] dp lt: state 3 (channel equalization), hpd 1, pending_lt_evt 0
[ 3.840980] Tonie’s Msg : lt: lt_data->tps3_supported 0
[ 3.842056] Tonie’s Msg : lt: get_channel_eq_status n_lanes 4
[ 3.842338] Tonie’s Msg : lt: read dpcd[0] status 17
[ 3.842341] dp lt: CE not done
[ 3.842904] dp lt: new config: lane 0: vs level: 0, pe level: 2, pc2 level: 0
[ 3.842908] dp lt: new config: lane 1: vs level: 0, pe level: 2, pc2 level: 0
[ 3.842912] dp lt: new config: lane 2: vs level: 0, pe level: 2, pc2 level: 0
[ 3.842915] dp lt: new config: lane 3: vs level: 0, pe level: 2, pc2 level: 0
[ 3.842924] sor1 dp lt: config: lane 0: vs level: 0, pe level: 2, pc2 level: 0
[ 3.842933] sor1 dp lt: config: lane 1: vs level: 0, pe level: 2, pc2 level: 0
[ 3.842942] sor1 dp lt: config: lane 2: vs level: 0, pe level: 2, pc2 level: 0
[ 3.842951] sor1 dp lt: config: lane 3: vs level: 0, pe level: 2, pc2 level: 0
[ 3.842997] tegradc tegradc.1: Tonie’s Msg dp: tegra_dc_dpaux_write
[ 3.843234] dp lt: CE retry
[ 3.843238] dp lt: switching from state 3 (channel equalization) to state 3 (channel equalization)
[ 3.843245] dp lt: state 3 (channel equalization), hpd 1, pending_lt_evt 0
[ 3.843248] Tonie’s Msg : lt: lt_data->tps3_supported 0
[ 3.844328] Tonie’s Msg : lt: get_channel_eq_status n_lanes 4
[ 3.844610] Tonie’s Msg : lt: read dpcd[0] status 17
[ 3.844611] dp lt: CE not done
[ 3.845183] dp lt: new config: lane 0: vs level: 0, pe level: 1, pc2 level: 0
[ 3.845187] dp lt: new config: lane 1: vs level: 0, pe level: 1, pc2 level: 0
[ 3.845190] dp lt: new config: lane 2: vs level: 0, pe level: 1, pc2 level: 0
[ 3.845193] dp lt: new config: lane 3: vs level: 0, pe level: 1, pc2 level: 0
[ 3.845202] sor1 dp lt: config: lane 0: vs level: 0, pe level: 1, pc2 level: 0
[ 3.845210] sor1 dp lt: config: lane 1: vs level: 0, pe level: 1, pc2 level: 0
[ 3.845219] sor1 dp lt: config: lane 2: vs level: 0, pe level: 1, pc2 level: 0
[ 3.845228] sor1 dp lt: config: lane 3: vs level: 0, pe level: 1, pc2 level: 0
[ 3.845275] tegradc tegradc.1: Tonie’s Msg dp: tegra_dc_dpaux_write
[ 3.845511] dp lt: CE retry
[ 3.845516] dp lt: switching from state 3 (channel equalization) to state 3 (channel equalization)
[ 3.845523] dp lt: state 3 (channel equalization), hpd 1, pending_lt_evt 0
[ 3.845526] Tonie’s Msg : lt: lt_data->tps3_supported 0
[ 3.846600] Tonie’s Msg : lt: get_channel_eq_status n_lanes 4
[ 3.846881] Tonie’s Msg : lt: read dpcd[0] status 17
[ 3.846883] dp lt: CE not done
[ 3.846886] dp lt: CE retry limit 5 reached
[ 3.846890] dp lt: switching from state 3 (channel equalization) to state 6 (reduce bit rate)
[ 3.846897] dp lt: state 6 (reduce bit rate), hpd 1, pending_lt_evt 0
[ 3.846903] dp lt: bit rate already lowest
[ 3.846909] tegradc tegradc.1: Tonie’s Msg dp: tegra_dc_dp_dpcd_write
[ 3.847421] tegradc tegradc.1: Tonie’s Msg dp: tegra_dc_dp_dpcd_write
[ 3.847943] tegradc tegradc.1: Tonie’s Msg dp: tegra_dc_dp_dpcd_write
[ 3.848168] dp lt: switching from state 6 (reduce bit rate) to state 4 (link training fail/disable)
[ 5.077584] tun: (C) 1999-2004 Max Krasnyansky maxk@qualcomm.com
[ 5.086401] PPP generic driver version 2.4.2
[ 5.092794] PPP BSD Compression module registered
[ 5.099455] PPP Deflate Compression module registered
[ 5.106555] PPP MPPE Compression module registered
[ 5.113416] NET: Registered protocol family 24
[ 5.120012] usbcore: registered new interface driver r8152
[ 5.127591] usbcore: registered new interface driver asix
[ 5.134977] usbcore: registered new interface driver ax88179_178a
[ 5.142970] usbcore: registered new interface driver cdc_ether
[ 5.150642] usbcore: registered new interface driver smsc95xx
[ 5.158134] usbcore: registered new interface driver net1080
[ 5.165504] usbcore: registered new interface driver cdc_subset
[ 5.173108] usbcore: registered new interface driver zaurus
[ 5.180368] usbcore: registered new interface driver cdc_ncm
[ 5.187784] usbcore: registered new interface driver usb-storage
[ 5.195439] usbcore: registered new interface driver usbserial
[ 5.202735] usbcore: registered new interface driver ftdi_sio
[ 5.209861] usbserial: USB Serial support registered for FTDI USB Serial Device
[ 5.218599] usbcore: registered new interface driver option
[ 5.225569] usbserial: USB Serial support registered for GSM modem (1-port)
[ 5.234042] usbcore: registered new interface driver pl2303
[ 5.241180] usbserial: USB Serial support registered for pl2303
[ 5.250153] tegra-xudc-new 700d0000.xudc: usb2 phy is not available yet
[ 5.390730] max77686-rtc max77620-rtc: rtc core: registered max77620-rtc as rtc1
[ 5.402143] tegra_rtc 7000e000.rtc: rtc core: registered 7000e000.rtc as rtc0
[ 5.410861] tegra_rtc 7000e000.rtc: Tegra internal Real Time Clock
[ 5.419184] i2c /dev entries driver
[ 5.426347] IR NEC protocol handler initialized
[ 5.432415] IR Sharp protocol handler initialized
[ 5.438633] IR XMP protocol handler initialized
[ 5.444751] usbcore: registered new interface driver uvcvideo
[ 5.452061] USB Video Class driver (1.1.1)
[ 5.458108] max77620-power max77620-power: Event recorder REG_NVERC : 0x0
[ 5.468894] tegra_soctherm 700e2000.soctherm: pllx_offset tz:0 max:14, min:2
[ 5.477756] tegra_soctherm 700e2000.soctherm: pllx_offset tz:1 max:8, min:4
[ 5.487112] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 5.500120] tegra_soctherm 700e2000.soctherm: thermtrip: will shut down when cpu reaches 102500 mC
[ 5.513152] tegra_soctherm 700e2000.soctherm: throttrip: will throttle when cpu reaches 100500 mC
[ 5.526762] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 5.540760] tegra_soctherm 700e2000.soctherm: thermtrip: will shut down when gpu reaches 103000 mC
[ 5.554522] tegra_soctherm 700e2000.soctherm: throttrip: will throttle when gpu reaches 101000 mC
[ 5.568628] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 5.582998] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature 2147483647 forced to 127000
[ 5.597373] tegra_soctherm 700e2000.soctherm: thermtrip: will shut down when pll reaches 127000 mC
[ 5.611822] tegra_soctherm 700e2000.soctherm: throttrip: pll: missing hot temperature
[ 5.623005] tegra_soctherm 700e2000.soctherm: failed to register sensor: -19
[ 5.634725] tegra_aotag tegra-aotag: Registering sensor 0
[ 5.643119] tegra_aotag tegra-aotag: Bound to TZ : ID 0
[ 5.651170] tegra_aotag tegra-aotag: Probe done [SUCCESS]:0
[ 5.660469] FAN dev name: pwm-fan
[ 5.666640] FAN:gpio request success.
[ 5.673146] pwm_fan_driver pwm-fan: cap state:7, cap pwm:255
[ 5.681883] pwm_fan_driver pwm-fan: unable to request PWM, trying legacy API
[ 5.691651] pwm_fan_driver pwm-fan: got pwm for fan
[ 5.699367] pwm_fan_driver pwm-fan: fan tach request irq success
[ 5.707934] pwm_fan_driver pwm-fan: tach period: 1000
[ 5.715559] pwm_fan_driver pwm-fan: index 0: pwm=0, rpm=0, rru=40, rrd=40, state:2
[ 5.725578] pwm_fan_driver pwm-fan: index 1: pwm=80, rpm=1000, rru=2, rrd=2, state:2
[ 5.735701] pwm_fan_driver pwm-fan: index 2: pwm=120, rpm=2000, rru=1, rrd=1, state:2
[ 5.745847] pwm_fan_driver pwm-fan: index 3: pwm=160, rpm=3000, rru=1, rrd=1, state:2
[ 5.755883] pwm_fan_driver pwm-fan: index 4: pwm=255, rpm=4000, rru=1, rrd=1, state:3
[ 5.765812] pwm_fan_driver pwm-fan: index 5: pwm=255, rpm=5000, rru=1, rrd=1, state:3
[ 5.775625] pwm_fan_driver pwm-fan: index 6: pwm=255, rpm=6000, rru=1, rrd=1, state:3
[ 5.785334] pwm_fan_driver pwm-fan: index 7: pwm=255, rpm=7000, rru=1, rrd=1, state:4
[ 5.794922] pwm_fan_driver pwm-fan: index 8: pwm=255, rpm=10000, rru=1, rrd=1, state:4
[ 5.804518] pwm_fan_driver pwm-fan: index 9: pwm=255, rpm=11000, rru=1, rrd=1, state:4
[ 5.815222] tegra-wdt 60005100.watchdog: Tegra WDT enabled on probe. Timeout = 120 seconds.
[ 5.826975] tegra-wdt 60005100.watchdog: initialized (timeout = 120 sec, nowayout = 1)
[ 5.836886] device-mapper: uevent: version 1.0.3
[ 5.843464] device-mapper: ioctl: 4.34.0-ioctl (2015-10-28) initialised: dm-devel@redhat.com
[ 5.859891] sdhci: Secure Digital Host Controller Interface driver
[ 5.867849] sdhci: Copyright(c) Pierre Ossman
[ 5.873920] sdhci-pltfm: SDHCI platform and OF driver helper
[ 5.882212] sdhci-tegra sdhci-tegra.3: Parent select= pll_p rate=408000000
[ 5.888972] tegra-se 70012000.se: tegra_se_probe: complete
[ 5.889801] hidraw: raw HID events driver (C) Jiri Kosina
[ 5.893266] usbcore: registered new interface driver usbhid
[ 5.893269] usbhid: USB HID core driver
[ 5.918579] sdhci-tegra sdhci-tegra.3: Parent select= pll_c4_out2 rate=199680000
[ 5.927934] sdhci-tegra sdhci-tegra.3: Client registration for eMC Successful
[ 5.938236] parse_throttle_dt_data: Num cap clks = 6
[ 5.945139] parse_throttle_dt_data: clk=cclk_g type=2
[ 5.952129] parse_throttle_dt_data: clk=gpu type=4
[ 5.958885] parse_throttle_dt_data: clk=cap.throttle.c2bus type=0
[ 5.966990] parse_throttle_dt_data: clk=cap.throttle.c3bus type=0
[ 5.971377] mmc0: SDHCI controller on sdhci-tegra.3 [sdhci-tegra.3] using ADMA 64-bit with 64 bit addr
[ 5.971741] sdhci-tegra sdhci-tegra.1: Parent select= pll_p rate=408000000
[ 5.971763] sdhci-tegra sdhci-tegra.1: Client registration for eMC Successful
[ 6.007013] parse_throttle_dt_data: clk=cap.throttle.sclk type=0
[ 6.007370] mmc1: SDHCI controller on sdhci-tegra.1 [sdhci-tegra.1] using ADMA 64-bit with 64 bit addr
[ 6.008086] sdhci-tegra sdhci-tegra.0: Got CD GPIO
[ 6.008136] sdhci-tegra sdhci-tegra.0: Got WP GPIO
[ 6.008222] sdhci-tegra sdhci-tegra.0: Parent select= pll_p rate=408000000
[ 6.008274] sdhci-tegra sdhci-tegra.0: wakeup init done, cd_irq: 262
[ 6.008295] sdhci-tegra sdhci-tegra.0: Client registration for eMC Successful
[ 6.010731] en-vdd-sd: supplied by vdd-3v3
[ 6.013969] mmc0: MAN_BKOPS_EN bit is not set
[ 6.021600] mmc0: Skipping tuning since strobe enabled
[ 6.027794] mmc0: new HS400 MMC card at address 0001
[ 6.028448] mmcblk0: mmc0:0001 016G32 14.7 GiB
[ 6.028658] mmcblk0rpmb: mmc0:0001 016G32 partition 3 4.00 MiB
[ 6.030006] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15 p16 p17 p18
[ 6.051605] mmc2: SDHCI controller on sdhci-tegra.0 [sdhci-tegra.0] using ADMA 64-bit with 64 bit addr
[ 6.076467] mmc1: queuing unknown CIS tuple 0x80 (5 bytes)
[ 6.139357] parse_throttle_dt_data: clk=emc type=3
[ 6.147031] tegra_throttle_probe: probe successful. #cdevs=4
[ 6.155182] tegra21x_actmon 6000c800.actmon: in actmon_register()…
[ 6.165299] tegra21x_actmon 6000c800.actmon: initialization Completed for the device mc_all
[ 6.179265] tegra124-dfll 70110000.clock: config PMU interface as PWM
[ 6.191818] No Device Node present for smmu client: snd-soc-dummy !!
[ 6.200331] platform snd-soc-dummy: No iommus property found in DT node, got swgids from fixup(101004000)
[ 6.214102] No Device Node present for smmu client: snd-soc-dummy !!
[ 6.222613] platform snd-soc-dummy: No iommus property found in DT node, got swgids from fixup(101004000)
[ 6.236940] No Device Node present for smmu client: snd-soc-dummy !!
[ 6.245673] snd-soc-dummy snd-soc-dummy: No iommus property found in DT node, got swgids from fixup(101004000)
[ 6.260466] No Device Node present for smmu client: snd-soc-dummy !!
[ 6.269309] snd-soc-dummy snd-soc-dummy: No iommus property found in DT node, got swgids from fixup(101004000)
[ 6.287970] input: tegra-hda HDMI/DP,pcm=3 as /devices/70030000.hda/sound/card0/input0
[ 6.306585] tegra210-i2s tegra210-i2s.0: Missing prop fsync-width for I2S0
[ 6.318041] tegra210-i2s tegra210-i2s.2: Missing prop fsync-width for I2S2
[ 6.328198] tegra210-i2s tegra210-i2s.3: Missing prop fsync-width for I2S3
[ 6.338343] tegra210-i2s tegra210-i2s.4: Missing prop fsync-width for I2S4
[ 6.360235] OPE platform probe
[ 6.365878] OPE platform probe successful
[ 6.372596] OPE platform probe
[ 6.378111] OPE platform probe successful
[ 6.386335] tegra-snd-t210ref-mobile-rt565x sound: Failed to get HP Det GPIO, should be handled by codec
[ 6.420100] mmc1 tuning done saved tap delay=44
[ 6.426864] mmc1: hw tuning done …
[ 6.432603] mmc1: tuning_window[0]: 0xf3ffffff
[ 6.434500] tegra-snd-t210ref-mobile-rt565x sound: ADMAIF1 ↔ ADMAIF1 mapping ok
[ 6.434727] tegra-snd-t210ref-mobile-rt565x sound: ADMAIF2 ↔ ADMAIF2 mapping ok
[ 6.434963] tegra-snd-t210ref-mobile-rt565x sound: ADMAIF3 ↔ ADMAIF3 mapping ok
[ 6.435191] tegra-snd-t210ref-mobile-rt565x sound: ADMAIF4 ↔ ADMAIF4 mapping ok
[ 6.435454] tegra-snd-t210ref-mobile-rt565x sound: ADMAIF5 ↔ ADMAIF5 mapping ok
[ 6.435688] tegra-snd-t210ref-mobile-rt565x sound: ADMAIF6 ↔ ADMAIF6 mapping ok
[ 6.435914] tegra-snd-t210ref-mobile-rt565x sound: ADMAIF7 ↔ ADMAIF7 mapping ok
[ 6.436141] tegra-snd-t210ref-mobile-rt565x sound: ADMAIF8 ↔ ADMAIF8 mapping ok
[ 6.436380] tegra-snd-t210ref-mobile-rt565x sound: ADMAIF9 ↔ ADMAIF9 mapping ok
[ 6.436610] tegra-snd-t210ref-mobile-rt565x sound: ADMAIF10 ↔ ADMAIF10 mapping ok
[ 6.530980] mmc1: tuning_window[1]: 0x3fffffff
[ 6.536613] mmc1: tuning_window[2]: 0xfffffffe
[ 6.542142] mmc1: tuning_window[3]: 0x7fffffe7
[ 6.547674] mmc1: tuning_window[4]: 0x0
[ 6.552599] mmc1: tuning_window[5]: 0x0
[ 6.557523] mmc1: tuning_window[6]: 0x0
[ 6.562360] mmc1: tuning_window[7]: 0x0
[ 6.567185] sdhci: Tap value: 44 | Trim value: 8
[ 6.572837] sdhci: SDMMC_VENDOR_INTR_STATUS[0x108]: 0x40000
[ 6.585174] input: tegra-snd-t210ref-mobile-rt565x Headphone Jack as /devices/sound/sound/card1/input1
[ 6.597698] mmc1: queuing unknown CIS tuple 0x91 (3 bytes)
[ 6.598234] tegra-snd-t210ref-mobile-rt565x sound: codec-dai “dit-hifi” registered
[ 6.598240] tegra-snd-t210ref-mobile-rt565x sound: This is a dummy codec
[ 6.599036] GACT probability NOT on
[ 6.599047] Mirror/redirect action on
[ 6.599062] u32 classifier
[ 6.599064] Actions configured
[ 6.599075] Netfilter messages via NETLINK v0.30.
[ 6.599140] nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
[ 6.599579] ctnetlink v0.93: registering with nfnetlink.
[ 6.613387] xt_time: kernel timezone is -0000
[ 6.613531] ipip: IPv4 over IPv4 tunneling driver
[ 6.614176] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 6.614317] arp_tables: (C) 2002 David S. Miller
[ 6.614385] Initializing XFRM netlink socket
[ 6.615208] NET: Registered protocol family 10
[ 6.621865] mip6: Mobile IPv6
[ 6.621893] ip6_tables: (C) 2000-2006 Netfilter Core Team
[ 6.622088] sit: IPv6 over IPv4 tunneling driver
[ 6.623176] NET: Registered protocol family 17
[ 6.623205] NET: Registered protocol family 15
[ 6.623243] bridge: automatic filtering via arp/ip/ip6tables has been deprecated. Update your scripts to load br_netfilter if you need this.
[ 6.623268] Key type dns_resolver registered
[ 6.625743] Registered cp15_barrier emulation handler
[ 6.633701] isp 54600000.isp: initialized
[ 6.635131] isp 54680000.isp: initialized
[ 6.639218] clk_cbus_recalc_rate: no gbus parent
[ 6.639225] clk_cbus_round_rate: no gbus parent
[ 6.639228] clk_cbus_round_rate: no gbus parent
[ 6.639236] clk_cbus_recalc_rate: no gbus parent
[ 6.639725] clk_cbus_recalc_rate: no gbus parent
[ 6.639731] clk_cbus_round_rate: no gbus parent
[ 6.639734] clk_cbus_round_rate: no gbus parent
[ 6.639740] clk_cbus_recalc_rate: no gbus parent
[ 6.639766] tegra_dvfs: GPU-cap: registered
[ 6.639855] tegra dvfs: vdd-cpu: nominal 1226mV, offset 708000uV, step 19200uV, scaling enabled
[ 6.639859] tegra dvfs: vdd-core: nominal 1125mV, offset 600000uV, step 12500uV, scaling enabled
[ 6.639863] tegra dvfs: vdd-gpu: nominal 1120mV, offset 710000uV, step 10000uV, scaling enabled
[ 6.641699] tegra_dvfs: vdd-gpu-vts: registered
[ 6.643699] xhci-tegra 70090000.xusb: can’t get usb3-0 phy (-517)
[ 6.644382] tegra21x-padctl-uphy 7009f000.pinctrl: padctl mmio start 0x000000007009f000 end 0x000000007009ffff
[ 6.644394] tegra21x-padctl-uphy 7009f000.pinctrl: TEGRA_FUSE_SKU_CALIB_0 0x81ea412
[ 6.644401] tegra21x-padctl-uphy 7009f000.pinctrl: TEGRA_FUSE_USB_CALIB_EXT_0 0x4
[ 6.645821] tegra21x-padctl-uphy 7009f000.pinctrl: UTMI-0 is used by XUSB
[ 6.645831] tegra21x-padctl-uphy 7009f000.pinctrl: using UTMI port 0 for otg
[ 6.645839] tegra21x-padctl-uphy 7009f000.pinctrl: UTMI-2 is used by XUSB
[ 6.645854] tegra21x-padctl-uphy 7009f000.pinctrl: uphy_lane = 5, set usb3_lanes = 0x20
[ 6.645872] tegra21x-padctl-uphy 7009f000.pinctrl: USB3 port 1 maps to USB2 port 2
[ 6.645879] tegra21x-padctl-uphy 7009f000.pinctrl: UTMI-1 is used by XUSB
[ 6.645893] tegra21x-padctl-uphy 7009f000.pinctrl: uphy_lane = 6, set usb3_lanes = 0x60
[ 6.645907] tegra21x-padctl-uphy 7009f000.pinctrl: USB3 port 0 maps to USB2 port 1
[ 6.645924] tegra21x-padctl-uphy 7009f000.pinctrl: uphy_lane = 1, set pcie_lanes = 0x2
[ 6.645946] tegra21x-padctl-uphy 7009f000.pinctrl: uphy_lane = 2, set pcie_lanes = 0x6
[ 6.645965] tegra21x-padctl-uphy 7009f000.pinctrl: uphy_lane = 3, set pcie_lanes = 0xe
[ 6.645984] tegra21x-padctl-uphy 7009f000.pinctrl: uphy_lane = 4, set pcie_lanes = 0x1e
[ 6.646003] tegra21x-padctl-uphy 7009f000.pinctrl: uphy_lane = 0, set pcie_lanes = 0x1f
[ 6.646024] tegra21x-padctl-uphy 7009f000.pinctrl: uphy_lane = 7, set sata_lanes = 0x80
[ 6.646740] usb-vbus1: supplied by vdd-3v3
[ 6.649163] tegra21x-padctl-uphy 7009f000.pinctrl: Done tegra21x_padctl_uphy_probe
[ 6.651987] tegra-pcie 1003000.pcie-controller: 4x1, 1x1 configuration
[ 6.652222] tegra-pcie 1003000.pcie-controller: PCIE: Enable power rails
[ 6.652942] clk_cbus_round_rate: no gbus parent
[ 6.652949] tegra_gpu_edp gpu_edp: unable to get max GPU freq
[ 6.653320] tegra-pcie 1003000.pcie-controller: probing port 0, using 4 lanes
[ 6.653537] tegra-ahci 70027000.sata: Missing devslp-active state
[ 6.654553] tegra-ahci 70027000.sata: AHCI 0001.0301 32 slots 2 ports 3 Gbps 0x1 impl platform mode
[ 6.654564] tegra-ahci 70027000.sata: flags: 64bit ncq sntf pm led pmp pio slum part deso sadm apst
[ 6.655448] tegra-pcie 1003000.pcie-controller: probing port 1, using 1 lanes
[ 6.655535] gk20a 57000000.gpu: GPCPLL initial settings: NA mode, M=1, N=34, P=3
[ 6.659997] scsi host0: tegra_ahci
[ 6.664555] scsi host1: tegra_ahci
[ 6.664799] ata1: SATA max UDMA/133 mmio [mem 0x70027000-0x70028fff] port 0x100 irq 372
[ 6.664803] ata2: DUMMY
[ 6.668982] tegra-xudc-new 700d0000.xudc: USB charger detection disabled
[ 6.669503] tegra-xudc-new 700d0000.xudc: entering ELPG
[ 6.670133] tegra_core_action core_dvfs_cdev_floor: Tegra CORE DVFS ‘floor cooling device’ registered
[ 6.670825] tegra21x-padctl-uphy 7009f000.pinctrl: trying to assert IDDQ while XUSB partitions are on
[ 6.671902] tegra_core_action core_dvfs_cdev_cap: Tegra CORE DVFS ‘cap cooling device’ registered
[ 6.672342] tegra_dfll_action dfll-cdev-cap: Tegra DFLL ‘cap cooling device’ registered
[ 6.673001] tegra-xudc-new 700d0000.xudc: entering ELPG done
[ 6.673225] tegra_dfll_action dfll-cdev-floor: Tegra DFLL ‘floor cooling device’ registered
[ 6.676100] xhci-tegra 70090000.xusb: UTMI port 0 has OTG_CAP
[ 6.676102] xhci-tegra 70090000.xusb: No USB3 port has OTG_CAP
[ 6.679394] xhci-tegra 70090000.xusb: Direct firmware load for tegra21x_xusb_firmware failed with error -2
[ 6.679396] xhci-tegra 70090000.xusb: Falling back to user helper
[ 6.681442] input: gpio-keys as /devices/gpio-keys/input/input2
[ 6.713912] tegra_rtc 7000e000.rtc: setting system clock to 2000-01-01 01:00:21 UTC (946688421)
[ 6.714739] vi 54080000.vi: vi_probe: ++
[ 6.720517] vi 54080000.vi: initialized
[ 6.722913] vi 54080000.vi: all channel register failed
[ 6.723830] Disable partitions left on by BL
[ 6.723831] disb
[ 6.733491] DRAM derating cdev registered.
[ 6.734337] vdd-cpu-fixed: disabling
[ 6.734347] vdd-cam-hv: disabling
[ 6.734431] avdd-ts-hv: disabling
[ 6.734496] vdd-ts: disabling
[ 6.734559] max77620-gpio7: disabling
[ 6.734698] en-vdd-cam: disabling
[ 6.734701] aux-3v3: disabling
[ 6.734702] snsr_pm: disabling
[ 6.734704] vdd-disp-3v0: disabling
[ 6.734707] vdd-fan: disabling
[ 6.734708] usb-vbus1: disabling
[ 6.734710] en-vdd-ts-1v8: disabling
[ 6.734712] en-vdd-ts-hv-3v3: disabling
[ 6.734714] en-mdm-pwr-3v7: disabling
[ 6.734716] en-vdd-cam-hv-2v8: disabling
[ 6.734718] rtl-5v0: disabling
[ 6.734719] en-usb-vbus2: disabling
[ 6.734721] en-vdd-cam-1v2: disabling
[ 6.734722] en-vdd-vcm-2v8: disabling
[ 6.735589] ALSA device list:
[ 6.735591] #0: tegra-hda at 0x70038000 irq 350
[ 6.735592] #1: tegra-snd-t210ref-mobile-rt565x
[ 6.991361] ata1: SATA link down (SStatus 0 SControl 300)
[ 7.079956] tegra-pcie 1003000.pcie-controller: link 0 down, retrying
[ 7.351461] mmc1: new ultra high speed SDR104 SDIO card at address 0001
[ 7.352513] EXT4-fs (mmcblk0p1): couldn’t mount as ext3 due to feature incompatibilities
[ 7.352720] EXT4-fs (mmcblk0p1): couldn’t mount as ext2 due to feature incompatibilities
[ 7.462019] EXT4-fs (mmcblk0p1): recovery complete
[ 7.468704] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
[ 7.478030] VFS: Mounted root (ext4 filesystem) on device 179:1.
[ 7.485812] devtmpfs: mounted
[ 7.489795] Freeing unused kernel memory: 1208K (ffffffc001163000 - ffffffc001291000)
[ 7.498441] Freeing alternatives memory: 76K (ffffffc001291000 - ffffffc0012a4000)
[ 7.519254] tegra-pcie 1003000.pcie-controller: link 0 down, retrying
[ 7.563122] systemd[1]: System time before build time, advancing clock.
[ 7.584850] random: systemd: uninitialized urandom read (16 bytes read, 82 bits of entropy available)
[ 7.597430] systemd[1]: systemd 229 running in system mode. (+PAM +AUDIT +
