I have been following the tutorial for making a simple robot with two wheels via tutorial_gui_simple_robot.
After adding the ROS extension, I can subscribe the values of the two wheel joints via the ROS command. However, I want to control the wheel moving using the ROS pub command, then I used following ROS command but nothing works. Did I miss something?
ros2 topic pub /mock/joint_command sensor_msgs/JointState "header:
stamp: {sec: 0, nanosec: 0}
frame_id: ''
name: [joint_left, joint_right]
position: [2.0, 2.0]
velocity: [0.0, 0.0]
effort: [0.0, 0.0]
Thanks for your time and consideration.
