Hi Nvidia,
The ECC of the DDR memory seesm to be disabled by default. Could you tell how to enable the ECC DDR memory setting in Xavier?
Hi Nvidia,
Hi eekevinlaw, Jetson AGX Xavier does not have ECC DDR memory, so there isn’t a way to enable it.
However it does use ECC protection in the on-chip L2/L3 caches, which is always enabled.
