I want make TX2 HDMI always output 1080P whatever moniter is.
suchb,
This request seems not valid if your monitor does not support 1080p…
I’ll help find if there is any setting you could use.
Thanks for your patience.
Thank you,WayneWWW
I know my issue could be illogical,but this is necessary in my case.
Looking forward to your reply.
Could you try to set below file as “monitors.xml” under ~/.config/. ?
<monitors version="1">
<configuration>
<clone>no</clone>
<output name="HDMI-0">
<vendor>ACR</vendor>
<product>0x0440</product>
<serial>0x52201c2a</serial>
<width>1920</width>
<height>1080</height>
<rate>60</rate>
<x>0</x>
<y>0</y>
<rotation>normal</rotation>
<reflect_x>no</reflect_x>
<reflect_y>no</reflect_y>
<primary>yes</primary>
</output>
</configuration>
</monitors>
WayneWWW,
Many thanks for the solution.
Is ~/.config/monitors.xml both are functional between GUI and Framebuffer mode?
This should work only for GUI mode.
It looks not worked with monitors.xml in GUI mode.
nvidia@tegra-ubuntu:~$ ls ./.config/
compiz-1 dconf evolution gnome-session gtk-3.0 ibus libaccounts-glib monitors.xml nautilus pulse Trolltech.conf unity update-notifier upstart user-dirs.dirs user-dirs.locale
nvidia@tegra-ubuntu:~$ xrandr
Screen 0: minimum 8 x 8, current 1280 x 800, maximum 32767 x 32767
HDMI-0 connected primary 1280x800+0+0 (normal left inverted right x axis y axis) 0mm x 0mm
1280x800 59.81*+
1920x1080 60.00 59.95 50.00
1280x768 59.87
1280x720 60.00 59.94 50.00
1024x768 75.03 70.07 60.01
800x600 75.00 72.19 60.32 56.25
720x576 50.00
720x480 59.94
720x400 70.04
640x480 75.00 72.81 59.94 59.94
hello,Anybody have a suggestion?
Have you directly added new xml file under ~/.config?
yes
Added monitors.xml file under ~/.config and reboot,test with a 1280x800 resolution monitor.
I want tx2 always output 1080P,but I still got 1280x800.
nvidia@tegra-ubuntu:~/.config$ ls
nvidia@tegra-ubuntu:~/.config$ cat monitors.xml
no
ACR
0x0440
0x52201c2a
1920
1080
60
0
0
normal
yes
nvidia@tegra-ubuntu:~/.config$ xrandr
Can’t open display
nvidia@tegra-ubuntu:~/.config$ export DISPLAY=:0.0
1280x800 59.81*+
1280x768 59.87
720x576 50.00
720x480 59.94
720x400 70.04
