Nvidia made a really stunning ting with Omniverse. I have just started to learn it. My problem the documentation is very confusing, it is not linear, difficult to follow. But the real problem is I can’t find in it how to render a picture and how to save it. It’s getting to drive me crazy :) Does anyone know it? :)
Hi @mypostafiok ,
Easiest way is to use F10 to take a screenshot of the viewport but by default that saves the UI too, so turn it off under Edit → preference-> Capture Screenshot → check the checkbox and fill in the saving path.
The other way you have to follow this documentation, which is using the movie capture tool where you could just render a frame or sequences.
https://docs.omniverse.nvidia.com/app_create/prod_extensions/ext_movie-capture.html
Rendering Basics — Omniverse Materials and Rendering documentation
Thank you. Yes that is the correct advise. Using the F10 key is the best way.
Thank you very much.
Omniverse for Blender is brilliant. Since I have found it I deleted native Blender and I use only this version.
Great. Glad you like it
