Hi ,
We want to use multi SPI devices(up to 8 or 6), so we need 8 gpio as cs signal and 8 gpios as interrupt signal. But the spi register failed with “could not get #gpio-cells for /interrupt-controller@3881000”?
kernel dmesg logs:
[ 1.661962] OF: /spi@3210000: could not get #gpio-cells for /interrupt-controller@3881000
[ 1.662181] spi-tegra114 3210000.spi: can not register to master err -22
[ 1.662559] spi-tegra114: probe of 3210000.spi failed with error -22
Can you give some help about interrupts settings through GPIO Expander?
HW: SPI1(3210000), two GPIO Expander TCA6408
SW: DTS configuration
i2c@31e0000 {
tca6408_20: tca6408@20 {
compatible = "ti,tca6408";
gpio-controller;
#gpio-cells = <2>;
reg = <0x20>;
vcc-supply = <&p2822_vdd_1v8_cvb>;
cs_outlow {
* GPIO-0 : CS1
* GPIO-1 : CS2
* GPIO-2 : CS3
* GPIO-3 : CS4
* GPIO-4 : CS5
* GPIO-5 : CS6
* GPIO-6 : CS7
* GPIO-7 : CS8
gpio-hog;
gpios = <0 0 1 0 2 0 3 0 4 0 5 0 6 0 7 0>;
output-low;
label = "cs1",
"cs2",
"cs3",
"cs4",
"cs5",
"cs6",
"cs7",
"cs8";
cs_outhigh {
status = "disabled";
cs_input {
tca6408_21: tca6408@21 {
reg = <0x21>;
gpio-controller;
#gpio-cells = <2>;
interrupt-controller;
#interrupt-cells = <2>;
int_outlow {
int_outhigh {
? How to configure interrupts ?
spi@3210000 {
status = "okay";
compatible = "nvidia,tegra186-spi";
cs-gpios = <&tca6408_20 0 >,
<&tca6408_20 1 >,
<&tca6408_20 2 >,
<&tca6408_20 3 >,
<&tca6408_20 4 >,
<&tca6408_20 5 >,
<&tca6408_20 6 >,
<&tca6408_20 7 >;
spidev0: spidev@0 {
compatible = "microchip,mcp28xd";
status = "okay";
reg = <0x0>;
interrupt-parent = <&tca6408_21>;
interrupts = <1 IRQ_TYPE_LEVEL_LOW>;
spi-max-frequency = <20000000>;
controller-data {
nvidia,cs-setup-clk-count = <0xF>;
nvidia,cs-hold-clk-count = <0xF>;
nvidia,tx-clk-tap-delay = <0x7>;
nvidia,rx-clk-tap-delay = <0x0>;
spidev1: spidev@1 {
status = "okay";
reg = <0x1>;
interrupts = <2 IRQ_TYPE_LEVEL_LOW>;
controller-data {
