- when I click button of Generate DT file ,there is no file to generate.why?
the file name is nv_Jetson-TX2-Series-Pinmux-Template.xlsm
hello lnu_liuyang,
may I know what’s the environment you’re used to generate DT files, is it windows operation system?
thanks
I download in Ubuntu 16.04.1 , then I click the button Generate DT file still no file to generate
I download the file from the Internet,and have no changes then click the button of Generate DT file.There is no file to generate.
hello lnu_liuyang,
that Generate DT files operation only available on Microsoft Windows OS,
you might also refer to Jetson Nano Developer Kit 40-Pin Expansion Header Configuration for reference,
thanks
Thank you very very much!
On Win10 ,when I click the button of Generate DT File ,the system shows error. The error is that the macro is disabled.When I clear the error ,the dts files are generated. So the problem is solved.Pretty so much!
