In one of the forum i heard need to check some clk reset control plle registers. But i am not able to find exact address for those registers. In TRM also i was not able to found.
I installed jet pack 5.1.2.
Product Jetson Agx orin dev kit
Which clock?
Spread spectrum clock
Suppose the SSC should default disable.
Do you want to check which clocks source’s SSC?
I followed below link to disable SSC :
How to disable Spread Spectrum Clocking(SSC) on Orin - Jetson & Embedded Systems / Jetson AGX Orin - NVIDIA Developer Forums
I want to just confirm, it is disabled. I got the offset values from code(spe-freertos-bsp) for these registers. Thanks
