I’m using JetPack 3.3 for tx2i.
- is SSC enabled by default ??
- how to disable SSC & How to confirm the changes have been effected ?
- is there any way to disable SSC for pci clock ??
thank you
thank you
Can you tell us the version you are using? I mean r28.2.1 / r31 / r32 etc??
SSC is enabled by default. I can suggest you the method based on the version.
im using r28.2.1 ( JetPack 3.3)
please let me know
In $TOP/platform/bpmp/ folder apply the following patch to disable Spread Spectrum for PCIe reference clock
diff --git a/tegra186-bpmp-quill.dtsi b/tegra186-bpmp-quill.dtsi
index 757923e233eb..e41b69aa63e4 100644
--- a/tegra186-bpmp-quill.dtsi
+++ b/tegra186-bpmp-quill.dtsi
@@ -14,3 +14,13 @@
#include "tegra186-platforms/tegra186-quill-clock.dtsi"
#include "tegra186-platforms/tegra186-quill-soctherm.dtsi"
+ clocks {
+ clock@plle {
+ clk-id = <TEGRA186_CLK_PLLE>;
+ /* disable ssc on PLLE */
+ pll_freq_table = <38400000 100000000 2 125 24 (-1) (-1) (-1) (-1)>;
To confirm if it is indeed disabled, read the value at address 0x05043000 and in that, bit-12 should be ‘1’ (‘0’ means enabled)
