I successfully ran the first container and could connect to it remotely. I then tried changing the ports with the second call to spin up a container, but it looks like the ports specified in the tutorial are still being used even by the 2nd container. How do I get the second container to use the new set of ports?
Call for first container
docker run --gpus all -e "ACCEPT_EULA=Y" -e "OMNI_USER=dockeruser" -e "OMNI_PASS=dockeruser" --rm --network=host -p 47995-48012:47995-48012/udp -p 47995-48012:47995-48012/tcp -p 49000-49007:49000-49007/tcp -p 49000-49007:49000-49007/udp nvcr.io/nvidia/isaac-sim:2020.2.2_ea
Call to second container
`docker run --gpus all -e "ACCEPT_EULA=Y" --rm -p 37995:37995/udp -p 37995:37995/tcp -p 38012:38012/tcp -p 38012:38012/udp nvcr.io/nvidia/isaac-sim:2020.2.2_ea`
