Hello.
Does Jetson nano’s HW HEVC encoder support B-frame and 10-bit depth output?
What is the difference from the HW encoder spec built into the Turing core GPU?
Hello.
HEVC encoder supports 10-bit color, but B-frames are not supported.
Thank you!
I see in various Xavier AGX specs that there is “12 bit support” in the encoder. What does that actually mean?
Does the TX2 also support any kind of 10-bit encoding?
thank you.
