On version 2022.1.1 it crashes when using the BasicWriter
Hi @vlad.crehul! Welcome to the forums. Could you gather your logs and add them here so a developer can take a look. There are instructions here about how to locate the log files: How to Report an issue with Omniverse
kit_20220816_161710.log (865.5 KB)
Thanks. I’ll forward this along to the devs.
Hello, for replicator you need to use the RTX renderer.
I’m quite sure I am using the ray tracing. Especially because at one point it actually worked. Never managed to reproduce this.
It also works fine in 2022.1.1 but something changed with scatter_2d that it doesn’t work with multiple planes.
def modifySemantics(prim, primString):
with prim:
rep.modify.semantics([('class', primString)])
modifySemantics(Object1, "Object1")
modifySemantics(Object2, "Object2")
modifySemantics(Plane1, "Plane1")
modifySemantics(Plane2, "Plane2")
planesList=[('class','Plane1'),('class','Plane2')]
objectList=[('class','Object1'), ('class', 'Object2')]
Object=rep.get.prims(semantics=objectList)
Planes=rep.get.prims(semantics=planesList)
with Object:
rep.randomizer.scatter_2d(Planes)
return Object.node
This does not work but it works with: planesList=[('class','Plane1')]
Hi @vlad.crehul. Just checking in to see if this is still any issue for you.
Haven’t tested it further because of the crashing, used the latest version instead. But I have this problem in the new versions.
Hi @vlad.crehul. I’ve opened internal issue OM-74642 and the dev team is looking into it.
Please try again with Code-2022.3 and let me know if you have any update that I can provide to the dev team.
Thank you!
