I cannot uninstall Omniverse and it has damaged my Windows 11
I installed Omniverse but it wasnt for me, so I uninstalled it.
I went under control panel and uninstalled Omniverse from there.
However, every time I start my computer up, I am greeted with “License Agreements”
If I decline, it closes, until next reboot, then I get the prompt again.
If I accept, I have to accept alot of stuff and then gets greeted with this screen:
This will come up every single time I start my computer. I also tried the Omniverse clean up tool, Launcher Cleanup Tool — Omniverse Utilities latest documentation, but it still happens.
First time I ran it, it could see my omniverse install, and removed it.
When I run it now, it cannot see any installed Omniverse stuff on my PC.
Is there a way I can remove this, or am I forced to reinstall my Windows 11 OS because of this tool?
Please help, as it is super annoying I have to do this every time I launch my PC!
I would start by simply going to ADD/REMOVE PROGRAMS and see if you can remove the actual Omniverse Launcher App.
Then look for all of these folders and delete them:
Launcher C:\Users\USER\AppData\Roaming\omniverse-launcher
Laucher Update C:\Users\USER\AppData\Local\omniverse-launcher-updater
Main OV Folder C:\Users\USER\AppData\local\ov
Apps C:\Users\USER\AppData\local\ov\pkgs
App Settings C:\Users\USER\AppData\local\ov\data\kit
Extensions C:\Users\USER\AppData\local\ov\data\Exts
Cache C:\Users\USER\AppData\local\ov\cache
Config & Logs C:\Users\USER.nvidia-omniverse
Kit Documents C:\Users\USER\Documents\Kit
Connectors C:\Users\USER\Documents\Omniverse
