I can't set proxy for nvidia omniverse
Env : Ubuntu 20.04, rtx3090
I launched the omniverse with command “./omniverse-launcher-linux.AppImage --proxy-server=123.123.45.678:8080”.(I write changed proxy server here for security.)
But error showed up like this.
Failed to get EULA, retrying in 2.5 seconds…
FetchError: request to https://messages.launcher.omniverse.nvidia.com/en/gdpr.json failed, reason: unable to verify the first certificate
at ClientRequest. (/tmp/.mount_omnivePJCwTP/resources/app.asar/dist/main.js:409:258863)
at ClientRequest.emit (node:events:527:28)
at TLSSocket.socketErrorListener (node:_http_client:454:9)
at TLSSocket.emit (node:events:527:28)
at emitErrorNT (node:internal/streams/destroy:157:8)
at emitErrorCloseNT (node:internal/streams/destroy:122:3)
at process.processTicksAndRejections (node:internal/process/task_queues:83:21)
How can I solve? Is there any correct way to set proxy? Please, help me.
Hi, thanks for posting and I’m sorry for the trouble. Do you use Discord so that we can discuss in more detail? If so, my Discord ID is Prof E#2041
I will also send you a message via forum.
P.S. Fall GTC sessions are now available for viewing: GTC 2022: #1 AI Conference
he / him | LinkedIn | Discord ID: Prof E#2041
Community Engagement for Omniverse: " A New Era of Digital Twins & Virtual Worlds with NVIDIA Omniverse" Video
What is NVIDIA Omniverse? Video | Check out the “Meet the Omnivore” blog series here
Omniverse Resources:
Omniverse | Documentation | Tech Requirements | Videos | Twitter | Discord | Twitch
The Omniverse documentation site has more info and links to all tutorial videos (under the “Learning and Feedback” category on left nav bar): Omniverse Platform Overview — Omniverse Developer documentation
PLEASE NOTE: If you are reporting a bug/issue, please provide OS, GPU, GPU Driver, the version of the app, and full log file (if applicable). For crashes, please zip and provide a link to your logs → C:\Users\ [YOUR NAME] \ .nvidia-omniverse\logs
Has anyone found a solution to this proxy issue ?
This works for windows using the solution mentioned here [Using a Proxy Server — Omniverse Launcher latest documentation]
But how to do the same in Ubuntu 22.04? Cannot create shortcut and add target proxy
That webpage help for Windows, also works the exact same way for Linux because it is just a command line argument. Not OS based.
That is great to hear
Could please tell me how can i use it exactly in terminal, I am new to ubuntu do not know much so i need to know steps how i can use it.
Thank you
