I have a video output problem in my jetson nano
The problem is that when I turn on my Jetson Nano the screen does not show the operating system, it says it does not detect a signal, what can I do to solve this problem?
Hi @mateocisneros055,
What process did you follow to set up your Jetson Nano? Did you flash the SD card with an image? If you haven’t done that yet, I recommend checking out this detailed guide: Jetson Nano - Getting Started.
Feel free to ask if you have any questions or need further assistance.
Best regards!
Oscar Mendez
Embedded SW Engineer at RidgeRun
Contact us: support@ridgerun.com
Developers wiki: https://developer.ridgerun.com/
Website: www.ridgerun.com
if it was working fine, i was using it to do a project but then the screen went black and now it doesn’t show anything from the operating system anymore
I understand,
Can you access the Jetson Nano through a serial connection? If so, could you check if there’s any output, and if possible, share the log? You can follow this guide to set up the serial connection: Jetson Nano - Getting into the Board.
Let me know if you have any questions or need further assistance.
Best regards!
Oscar Mendez
I have another model of jetson nano and it does not have the same pins, how can I do it?
anyone know what to do?
Please refer to below topics to see if can help:
Guidance to tell if you are using a NV developer kit - Jetson & Embedded Systems / Jetson Nano - NVIDIA Developer Forums
Debug tips when you hit any issue (fail to boot/ keep reboot …etc) - Jetson & Embedded Systems / Jetson Nano - NVIDIA Developer Forums
