Just like the title says. I am trying to download Jetpack 4.3 and it doesn’t download and is simply halted at 80%. Is there a command line way to go about this without the sdk so that I can check where in the shell script the download stops.
The last lines in the terminal (when using the sdk are as follows)
12:26:29 INFO: OpenCV on Target: download /media/lahiru/Seagate/nvnidia_jp_43/downloadagainonly/OpenCV-4.1.1-2-gd5a58aa75-aarch64-libs.deb successfully, checksum is correct
12:26:29 INFO: DevTools Documentation: download /media/lahiru/Seagate/nvnidia_jp_43/downloadagainonly/devtools_docs.zip successfully, checksum is correct
12:26:31 INFO: CUDA Toolkit for L4T: verifying checksum of /media/lahiru/Seagate/nvnidia_jp_43/downloadagainonly/cuda-repo-l4t-10-0-local-10.0.326_1.0-1_arm64.deb
12:26:32 INFO: CUDA on Host: verifying checksum of /media/lahiru/Seagate/nvnidia_jp_43/downloadagainonly/cuda-repo-ubuntu1804-10-0-local-10.0.326-410.108_1.0-1_amd64.deb
12:26:52 INFO: CUDA Toolkit for L4T: download /media/lahiru/Seagate/nvnidia_jp_43/downloadagainonly/cuda-repo-l4t-10-0-local-10.0.326_1.0-1_arm64.deb successfully, checksum is correct
12:26:56 INFO: CUDA on Host: download /media/lahiru/Seagate/nvnidia_jp_43/downloadagainonly/cuda-repo-ubuntu1804-10-0-local-10.0.326-410.108_1.0-1_amd64.deb successfully, checksum is correct
