but, I don’t know how to boot what I’m trying to do… please I would appreciate it if you could tell me how to flash. (I tried using jetpack but got stuck in several config parts)
AGX Xavier module can’t work on Jetson Nano carrier board, but Xavier NX module can.
Please check Considerations when using Jetson Xavier NX module with Nano devkit carrier - Jetson & Embedded Systems / Jetson Xavier NX - NVIDIA Developer Forums
You would still select the Xavier NX at the JetPack to do the image flash on your device.
Thank you for answer. I tried to boot nano board with xavier nx module using jetpack. Of course I used a barrel jack.
Please tell me how to flash xavier nx module using jetpack. And please tell me how to do recovery mode on nano board
Check quick start guide for the recovery mode.
https://developer.nvidia.com/embedded/downloads#?search=quick
Check sdkmanager for flashing the board.
