Based on the provided context, it appears that you are working with a custom carrier board based on the NVIDIA Jetson platform, specifically the Jetson AGX Orin module. You are trying to enable an I2C bus on your custom carrier board, which is mapped to specific pins.
To enable the I2C bus, you modified a file during flashing, but the specific file is not mentioned in your question. However, based on the context, it is likely that you modified a device tree file or a configuration file related to the I2C bus.
Here are some general steps and considerations for enabling an I2C bus on a custom carrier board based on the Jetson AGX Orin module:
- Device Tree: The device tree is a data structure that describes the hardware components of your system. To enable an I2C bus, you need to modify the device tree file to include the I2C bus and its corresponding pins. You can use the
jetson-agx-orin-devkit.conf file as a reference to modify the device tree file.
- Pinmux: The pinmux (pin multiplexing) configuration determines how the pins on the Jetson module are used. You need to configure the pinmux to assign the correct pins to the I2C bus. You can use the
jetson-agx-orin-devkit.conf file as a reference to modify the pinmux configuration.
- I2C Bus Configuration: You need to configure the I2C bus to use the correct pins and settings. This can be done by modifying the
i2c node in the device tree file or by using a configuration file specific to the I2C bus.
- Flashing: After modifying the device tree file and pinmux configuration, you need to flash the new configuration to the Jetson module. This can be done using the
flash.sh script or by using a custom flashing tool.
Some important considerations when enabling an I2C bus on a custom carrier board:
- Pin Compatibility: Make sure that the pins you are using for the I2C bus are compatible with the Jetson AGX Orin module. You can refer to the Jetson AGX Orin module’s datasheet or the NVIDIA Jetson Linux Developer Guide for more information on pin compatibility.
- I2C Bus Speed: The I2C bus speed needs to be configured correctly to ensure proper communication between devices on the bus. You can refer to the I2C bus specification or the device tree file for more information on configuring the I2C bus speed.
- Device Tree Overlay: If you are using a device tree overlay to enable the I2C bus, make sure that the overlay is correctly configured and applied during the boot process.
In comparison to other Jetson modules, the Jetson AGX Orin module has a similar process for enabling an I2C bus. However, the specific pinmux configuration and device tree file may differ depending on the module and carrier board design.
For example, the Jetson Orin NX module has a similar process for enabling an I2C bus, but the pinmux configuration and device tree file may differ due to the different pinout and hardware components.
In summary, to enable an I2C bus on a custom carrier board based on the Jetson AGX Orin module, you need to modify the device tree file, pinmux configuration, and I2C bus configuration, and then flash the new configuration to the Jetson module. Make sure to consider pin compatibility, I2C bus speed, and device tree overlay configuration to ensure proper communication between devices on the bus.
