Please provide the following info (check/uncheck the boxes after creating this topic): Software Version
DRIVE OS Linux 5.2.6
DRIVE OS Linux 5.2.6 and DriveWorks 4.0
DRIVE OS Linux 5.2.0
other DRIVE OS version
other
every time we start the NVIDIA devkit, the machine is always unresponsive, and we always need to disconnect/connect the power switch many times to boot successfully.
But even if it is turned on successfully occasionally, it will occasionally be accompanied by the XavierB screen/keyboard USB interface/both have no signal source.
What I’m trying to understand is, do you know what exactly is causing these situations? Do you have a way to improve the situation?
Dear @jieming.xu,
Does that mean it does not start (no fans running and light blinking) after couple of seconds
It will occasionally be accompanied by the XavierB screen/keyboard USB interface/both have no signal source
It means No Tegra B GUI is seen on monitor? I assume you have connected to correct HDMI port on Target.
How about updating to latest release to see if it fixes this issue?
Yes, it has nothing, no fans running and light blinking.
Yes, I have connected to correct HDMI and USB port and there has nothing on monitor.
About your suggestion, I will try it, you think that it is the problem of the version???
and I tried to boot it this morning , it has not any feedback until now.
