Hi, I am using a jetson nano with a dusty-nv docker for ros2 humble. I tried to install it from command as “sudo apt install ros-humble-filters” and didn’t worked so I tried to install it from source. When builiding it I have this error.
Hope you can help me.
Hi @thiagoromero42, can you try cloning the ros2 branch of that repo instead?
Or here is a way that you can pull/build ROS packages from source using rosinstall_generator or rosdep:
(replace gazebo_ros_pkgs with the ROS package names that you want)
thanks! cloning only the branch solve the problem.
