14:16:11.206 › Logged in.
14:16:11.207 › Can’t access the /home/dongchan/.nvidia-omniverse/config/privacy.toml file: ENOENT: no such file or directory, access ‘/home/dongchan/.nvidia-omniverse/config/privacy.toml’
14:16:33.398 › FetchError: request to https://launcher-index-prod.s3.amazonaws.com/en/components.json failed, reason: read ECONNRESET
at ClientRequest. (/tmp/.mount_omniveWuList/resources/app.asar/dist/main.js:345:256313)
at ClientRequest.emit (node:events:390:28)
at TLSSocket.socketErrorListener (node:_http_client:447:9)
at TLSSocket.emit (node:events:390:28)
at emitErrorNT (node:internal/streams/destroy:157:8)
at emitErrorCloseNT (node:internal/streams/destroy:122:3)
at processTicksAndRejections (node:internal/process/task_queues:83:21)
14:16:33.399 › Error occurred in handler for ‘prepare-install’: FetchError: request to https://launcher-index-prod.s3.amazonaws.com/en/components.json failed, reason: read ECONNRESET
14:16:39.982 › FetchError: request to https://launcher-index-prod.s3.amazonaws.com/en/components.json failed, reason: read ECONNRESET
14:16:39.983 › Error occurred in handler for ‘prepare-install’: FetchError: request to https://launcher-index-prod.s3.amazonaws.com/en/components.json failed, reason: read ECONNRESET
14:16:53.622 › FetchError: request to https://launcher-index-prod.s3.amazonaws.com/en/components.json failed, reason: read ECONNRESET
14:16:53.623 › Error occurred in handler for ‘prepare-install’: FetchError: request to https://launcher-index-prod.s3.amazonaws.com/en/components.json failed, reason: read ECONNRESET
14:17:13.103 › FetchError: request to https://launcher-index-prod.s3.amazonaws.com/en/components.json failed, reason: read ECONNRESET
14:17:13.104 › Error occurred in handler for ‘nucleus-install’: FetchError: request to https://launcher-index-prod.s3.amazonaws.com/en/components.json failed, reason: read ECONNRESET
Hello @dongchanyear! Sorry to hear you are having an issue connecting. What is your current system environment? OS, GPU / GPU Driver?
Also, could you include a full copy of your logs found here: %HOMEPATH%\.nvidia-omniverse\logs
