I am new to the sys-admin side of the Linux world and hence my problems - I am in the process of setting up a multi-machine network, sharing a 2-user floating license. I have already set up the PGI Fortran server on one of the machines and is up and running with a permanent license key. My problem is that I dont know how to make the other machines on the network use the floating license that was installed on the first machine.
I did not see anything on this issue in the PGI install files. Any advice in this regard will be appreciated.
Thanks,
Rooni.
Hi Rooni,
There are a couple different ways.
- Copy the license.dat file you use for your license manager and copy it to the $PGI directory (typically /opt/pgi) on each of the other systems.
- Copy a license.dat file to each system that includes the server name, the server’s hostid, port number, and “USE_SERVER”. For example:
server myserver 0014227A1234 27000
USE_SERVER
For options 1 and 2, users need to set the variable “LM_LICENSE_FILE” to “$PGI/license.dat” in their shell’s environment.
- Finally, instead of setting “LM_LICENSE_FILE” to a local license file, you have your users set it to “port@servername”. For example:
export LM_LICENSE_FILE=27000@myserver.mynetwork.net
Hope this helps,
Mat
I took the second option and it worked. Thank you.
Rooni.
