Intern error no file named for avt-nvidia-l4t-bootloader:arm64
Hi
I have a jetson nano div kit 4GB i flashed on it the jetpack 4.6.1 so i use it to connect a CSI-2 camera from Allied vision i have adabter board between the camera and the jetson board ofc. when instatlling the driver provided by allied vision in thier github page
i faced this error
i tried to do the upgrade sudo apt-get upgrade still the same problem with the bootloader
am new to all of the linux and the jetson nano things so i hope you take it easy on me.
thnak you.
Due to install customized driver cause the problem. I would suggest consult with vendor to get supported.
thank you for your relpy
i will consult the vendor buti still wondering if this customized driver could cause this similar error by system upgrade ?
thanks
