Please provide the following info (check/uncheck the boxes after creating this topic): Software Version
DRIVE OS Linux 5.2.6
DRIVE OS Linux 5.2.0
other DRIVE OS version
other
Also 5.2 does not seem to have sample code that builds sample app like nvmipp_file.
Is there any replacement for IPP in 5.2 ? if so what is it called ?
It seems SIPL is the replacement. Does it support capability to feed ISP from prerecorded images/video (i.e. file feed) ? From quick read of SIPL I am unable to figure out which API to use for feeding ISP from files as opposed to live camera images ?
Please take a look at nvsipl_reprocess under ~/nvidia/nvidia_sdk/DRIVE_OS_5.2.0_SDK_Linux_OS_*/DRIVEOS/drive-t186ref-linux/samples/nvmedia/nvsipl/test/reprocess/ in your host system.
But unfortunately, the source isn’t included in our releases.
nvsipl_reprocess app is targeted for IQ tuning and we consider the implementation as our IP. nvsipl_sample application has code that you can use as a reference to reprocess through SIPL.
Please take a look at “File input mode” in the document. Thanks.
