Currently only having Surface Pro laptop at work, needing to flash the Xavier AGX. Would it be possible to set up WSL 2 and flashing my Xavier from there?
So far as I know, even if you had a lot of knowledge and patience, WSL will not work. WSL does not support loopback, which is mandatory. A full VM could work, but this will probably need extra knowledge to make the USB work correctly (and I don’t even know what kind of USB a Surface Pro supports). VMs are never officially supported due to the USB side.
I had success flashing my Xavier-AGX with a Ubuntu-VM running in Virtualbox on a Mac. During setup/flashing the AGX reboots several times and you need to watch this carefully and reconnect the USB port in Virtualbox quickly before SDK-manager times out.
For WSL (1 or 2, doesn’t matter in this case), USB devices aren’t exposed to the guest. As such, this is not possible.
However, I can endorse what @dkreutz said, I reflashed my Xavier from my Mac w/ a VirtualBox VM in the past just fine.
