Is there a resolution limitation when using image sensor?
I did bring up an image sensor, which supports 1536x1552. I changed v4l2 mode table and I could see the image from the sensor. But the image was not clear and the edges have ‘check pattern’. I changed the resolution to 1920x1080 and I see the clear image. My question is, I think there is a resolution limitation. Is it correct? (when bypass_mode=0) In that case, I want to know the restriction in detail.
Thank you in advance.
@jw.cs.park
  • for nvarguscamerasrc(ISP pipeline), max supported line buffer, m_maxIspWidth0=6144
  • Maximum raw (Bayer) resolution through ISP
    • Nano - 24 Mpx
    • Xavier - 24 Mpx
    • TX2 - 24 Mpx
