I am working with Isaac gym using Tiago robot. The purpose is to push the object from the table to surface. I have set the position of gripper frame above the table surface but gripper tip always comes in contact of the table surface which makes the pushing action difficult I want to set the gripper tip small above from the table surface like hand should not interact with surface. Can someone suggest the solution for this problem
Related topics
Topic | Replies | Views | Activity | |
How to improve stability when grasping an object | 12 | 1952 | April 5, 2024 | |
The gripper cannot lift the object to the desired height | 2 | 51 | December 13, 2024 | |
Wrong Surface Gripper gripping position after changing robot position | 3 | 501 | October 19, 2023 | |
Object Gripping and picking | 5 | 1225 | August 5, 2024 | |
Wrong parallel gripper position when gripping an object | 2 | 558 | June 6, 2023 | |
Objects not colliding accurately | 2 | 957 | May 7, 2023 | |
Is it possible to support sucking robotic arm? | 4 | 1208 | May 12, 2023 | |
Robotiq gripper grasping problem | 3 | 73 | April 16, 2025 | |
Parallel gripper not holding the box firmly enough | 3 | 595 | February 19, 2024 | |
[BUG] Position Control | 3 | 474 | August 23, 2023 |
