In my Isaac Sim project, there are two robots equipped with grippers. I use GetPrimAtPath()
to access the motion axes and configure the opening and closing motions of the grippers using GetAttribute("drive:linear:physics:targetPosition").Set()
to grab objects. I have set the static and dynamic friction values of both gripper fingers and the object being grabbed to 1.
I noticed that when lifting the object directly using inverse kinematics, the object seems to get stuck at a certain height and cannot move upward further. However, using single-axis motion, the object can be lifted to a higher position. And when I use the Surface Gripper Controller, everything works fine, and I can grasp objects and move them to any position without issues. I wonder if anyone has encountered a similar issue and can provide assistance.
Isaac Sim Version
4.2.0
Operating System
Ubuntu 22.04
GPU Information
- Model: RTX 4080
- Driver Version: 550.120
