That is the result when I change the Local rotation 1 values to the x -90 y 0 z -90
also, it is not showing me the edits in the graphics, does there a solution for that ?
Aren’t you use fixjoint for just fixing two prims?
The reason why I asked, I think the fixed joints are used for fixing two prims so it doesn’t need to change the values in my case. Is there another object to use a fixed joint?
Hello! indeed that interface is not the most intuitive for authoring joints between two components.
It’s probably easier to explain in a video, so here it goes
