Highlights of the Isaac Sim 2022.2.1 Release
Kit SDK 104.2
Ubuntu 18.04 is no longer supported.
Sensors
- Surface Materials added for RTX Lidar.
Warehouse logistics
- Bug fixes
ROS
Updated ROS2 MoveIt tutorial.
Deprecated ROS Migration Tutorial from Sim 2021.2.1 and Isaac Sim 2022.2.0.
Custom python/C++ omnigraph nodes.
Isaac Gym
Omniverse Isaac Gym Environments Added Factory Nut/Bolt Pick environment and SAC Ant/Humanoid environments.
Added support for docker and live stream, along with multi-GPU training
Fixed run-time material randomization affecting friction and restitution.
Bug fixes
Isaac Replicator
- Added Basic UI for Composer to view/preview the generated scenarios.
Cortex
Docstring, comments, type hints, remove unused functions/files.
Convert all monitors to use add_monitors() API in examples.
DfContext converted to DfRobotApiContext (base class) and DfBasicContext (instantiation)
Backward compatible API update to CortexObjectsRos and CortexSimObjectsRos to fix hard coded in_coords.
People
Reduced steps for setting up characters by automating attaching behavior scripts and anim.graph.
New spawn command introduced for characters which allows a simulation to be tied to only the command file and not a USD.
Navigation API changes based on feedback from users.
Added a new command text box as an alternative to provide commands from within the App.
Revamped UI
Orbit
Support for skrl library for reinforcement learning.
Added utility to convert URDF to USD using command line arguments.
Fixed issue with setting camera pose in ROS convention.
Added support for other camera models offered by Replicator.
Extension
Omni.isaac.extension_templates UI to generate Extension templates to download python extension templates locally Extension templates significantly reduce the complexity of building a custom UI application in Isaac Sim.
Omni.isaac.ui.element_wrappers Created a set of UI element wrappers in omni.isaac.ui that significantly reduce the complexity of making a UI-based extension in Isaac Sim that aesthetically matches other extensions Available wrappers are shown in the extension template “UI Component Library.”
More information can be found at:
