6.0.0
5.1.0
5.0.0
4.5.0
4.2.0
4.1.0
4.0.0
4.5.0
2023.1.1
2023.1.0-hotfix.1
Other (please specify):
Operating System
Ubuntu 24.04
Ubuntu 22.04
Ubuntu 20.04
Windows 11
Windows 10
GPU Information
- Model: NVIDIA RTX 5070 Ti Laptop GPU (Blackwell architecture, 12GB VRAM)
- Driver Version: 595.79 (CRASH) / 591.74 (WORKS)
Topic Description
Isaac Sim 5.1.0 GUI mode crashes on RTX 5070 Ti (Blackwell) with driver 595.79. Headless mode works perfectly.
Detailed Description
Isaac Sim 5.1.0 installed via pip crashes approximately 20 seconds after the “app ready” message when running in GUI mode on an RTX 5070 Ti Laptop GPU (Blackwell architecture) with NVIDIA driver 595.79.
The crash occurs in omni.kit.window.preferences with an access violation error. The application window appears briefly and then terminates.
Headless mode (–headless) works flawlessly on the same system with the same driver, using the D3D12 renderer. The issue appears to be specific to the Vulkan rendering path on Blackwell GPUs with the 595.xx driver branch.
Downgrading the NVIDIA driver from 595.79 to 591.74 resolves the issue completely. Both GUI and headless modes work without any problems on 591.74.
System specs:
- GPU: NVIDIA RTX 5070 Ti Laptop (Blackwell, 12GB VRAM)
- CPU: Intel Core i9-13900HX
- RAM: 32 GB
- OS: Windows 11 Pro
- Isaac Sim: 5.1.0 (pip)
- Isaac Lab: 0.48.0 (release/2.3.0 branch)
- Python: 3.11 (Anaconda)
- PyTorch: 2.7.0+cu128
Steps to Reproduce
- System: RTX 5070 Ti (Blackwell) + Windows 11 + NVIDIA driver 595.79
- Install Isaac Sim 5.1.0 via pip (pip install isaacsim==5.1.0 --extra-index-url https://pypi.nvidia.com)
- Launch any script in GUI mode (without --headless flag)
- Wait ~20 seconds after “app ready” appears in console
- Application crashes with access violation in omni.kit.window.preferences
Error Messages
Access violation in omni.kit.window.preferences extension, approximately 20 seconds after application reports ready state. No detailed stack trace available as the application terminates abruptly.
Screenshots or Videos
N/A — application crashes before meaningful interaction is possible.
Additional Information
What I’ve Tried
All of the following failed to resolve the issue on driver 595.79:
- Cleared shader cache
- Forced D3D12 renderer via --/renderer/active=d3d12
- Disabled hotkeys extension (omni.kit.window.hotkeys)
- Upgraded Isaac Lab from 0.48.0 to 2.3.0
- Attempted migration to Isaac Sim 6.0 (not yet supported on Windows)
- Clean conda environment rebuild with fresh Isaac Sim 5.1.0 install
SOLUTION: Downgrading NVIDIA driver from 595.79 to 591.74 fixed the issue immediately.
Related Issues
No existing forum posts found for this specific Blackwell + 595.xx driver combination.
This may affect other Blackwell GPUs (RTX 5080, 5090) on the 595.xx driver branch.
Additional Context
Posting this to help other Blackwell GPU users avoid the same debugging process. The key takeaway: if Isaac Sim 5.1 GUI crashes on a Blackwell GPU, try downgrading to driver 591.74 before attempting any other fixes.
Working configuration:
- Driver: 591.74
- Isaac Sim: 5.1.0
- Isaac Lab: 0.48.0 (release/2.3.0)
- Python: 3.11
- GUI: Working
- Headless: Working
