Isaac Sim Version
6.0.1
Operating System
Ubuntu 24.04.03
GPU Information
- Model: GB10
- Driver Version: 580.173.02
Topic Description
I have build failures when I try to build isaac-sim-6.0.1 from source.
Detailed Description
[0.082s] [ext: omni.kit.registry.nucleus-0.0.0] startup
I: Initializing Version 2.71.2-release.7083+gl.9dc344f0
I: Client ID: ATTWL3CG
I: Not using Hub: Hub not found
I: Successfully created Azure provider for https://ovextensionsprod.blob.core.windows.net
2026-08-03T21:37:08Z [4,717ms] [Error] [omni.ext.plugin] Failed to resolve extension dependencies. Failure hints:
* No versions of omni.kit.quicklayout that satisfies: isaacsim.action_and_event_data_generation.setup-0.6.0 depends on omni.kit.quicklayout version *
- Available packages for omni.kit.quicklayout version *:
(none found)
Synced registries:
- kit/prod/default : found 2879 packages
- kit/prod/sdk : found 0 packages (couldn't connect or empty)
- isaacsim/prod/6.0 : found 350 packages
2026-08-03T21:37:08Z [4,717ms] [Error] [omni.kit.app.plugin] Failed to generate version file, kit file: isaacsim.exp.extscache-0.0.0 failed to resolve dependencies.
2026-08-03T21:37:08Z [4,717ms] [Error] [omni.kit.app.plugin] Exiting app because of dependency solver failure...
[08/04/26 01:37:08] ERROR error running: /home/developer/mount/project/software/tutorial/isaac-sim/third-party/isaac-sim/isaacsim/_build/linux-aarch64/release/kit/kit utils.py:422
/home/developer/mount/project/software/tutorial/isaac-sim/third-party/isaac-sim/isaacsim/_build/linux-aarch64/release/apps/isaacsim.exp.extscache.kit --allow-root --portable --ext-precache-mode --/crashreporter/gatherUserStory=0
--/app/settings/persistent=0 --/app/settings/loadUserConfig=0 --/app/extensions/generateVersionLock=1 --/app/extensions/parallelPullEnabled=1 --/app/enableStdoutOutput=1 --/app/extensions/detailedSolverExplanation=1
--/app/extensions/registryEnabled=1 --/app/extensions/mkdirExtFolders=0 '--/app/extensions/registryCacheFull='"'"'/home/developer/mount/project/software/tutorial/isaac-sim/third-party/isaac-sim/isaacsim/_build/linux-aarch64/release/extscache'"'"''
--/log/flushStandardStreamOutput=1 --/app/extensions/target/config=release --ext-folder /home/developer/mount/project/software/tutorial/isaac-sim/third-party/isaac-sim/isaacsim/_build/linux-aarch64/release/exts --ext-folder
/home/developer/mount/project/software/tutorial/isaac-sim/third-party/isaac-sim/isaacsim/_build/linux-aarch64/release/extsDeprecated, code: 55, message: ""
ERROR SystemExit exception stack trace dumped to logfile /home/developer/mount/project/software/tutorial/isaac-sim/third-party/isaac-sim/isaacsim/_repo/repo.log. Stacks dumped to console via `--verbose` or `--tracebacks`. log.py:250
SystemExit: 55
[08/04/26 01:37:08] ERROR error running: /home/developer/mount/project/software/tutorial/isaac-sim/third-party/isaac-sim/isaacsim/repo.sh precache_exts -c release, code: 55, message: "" utils.py:422
WARNING Retrieving repo_build version via VERSION file. version.py:316
SystemExit: 55
Steps to Reproduce
- ./build.sh
