Isaac Sim autoload extension hang
I installed the omni.kit.livestream.webrtc extension (I followed this tutorial) and enabled autoload. But now when i start isaac sim, it’s stuck in the startup process.
Thats the last output in the Terminal: [5.134s] [ext: omni.kit.livestream.webrtc-0.1.0] startup
Can i disable autoload in a config file or via command line arguments?
Hi @d.kalteis
You can edit the ~/.local/share/ov/data/Kit/Isaac-Sim/2022.1/user.config.json file and delete the extension entry under the "enabled" key
