Isaac Sim import fbx but no textures
Hi there~
I have a tunnel model with fbx like the first photo.
When I try to import to Isaac Sim, it becomes the second photo.
(isaac sim → File → Import)
It seems like that it doesn’t import the textures successfully.
Is anyone know how to import fbx models correctly???
Have you tried importing this asset into other DCCs like Blender or 3ds Max?
Some FBX files, depending on how they were exported, will not work because the texture paths are incorrect within the FBX or material definitions in the FBX are not defined.
If it can import into other DCCs correctly and you can share the FBX with me I could take a look to understand why it’s not working.
@a0939890213 , were you able to resolve the issue?, if not then please provide your response as requested in previous message.
Meanwhile, you can try this video and see if it helps resolve your issue: Omniverse Create - Importing FBX Files | NVIDIA Omniverse Tutorials - YouTube
