Please try using the recommended driver versions 535.129.03 and 570.144, as mentioned in Isaac Sim Requirements — Isaac Sim Documentation. Also, please follow those note there:
We recommend installing the Latest Production Branch Version drivers from the Unix Driver Archive using the .run installer on Linux, if you are on a new GPU or experiencing issues with the current drivers.
After updating your drivers, if you still encounter this issue, could you check the first few messages that appear when launching Isaac Sim to locate the log file? Please reproduce the issue, and then upload the log file here so we can investigate further.
