Issue flashing SSD with SDK manager
I am trying to flash the latest version of JetPack 5.1.2 on a XavierNX developer kit. When I flash the root partition does not use the full size of the SDD (1024gb) and 15 partitions are created.
I tried to change some files in SDK manager as the following post, but the flash process gets stuck on 99%:
When trying to flash the SDK manager displays a message:
Installation of ‘Flash Jetson Linux’ is taking longer than expected.
Do you want to continue installing this package?
I am attaching the logs.
This is the last part of the logs:
17:28:58 INFO: Flash Jetson Linux - flash: [ 7.3381 ] tegrasign_v3.py --key None --list blob_tegra194-p3668-0000-p3509-0000_aligned_sigheader.dtb_list.xml --pubkeyhash pub_key.key
17:28:58 INFO: Flash Jetson Linux - flash: [ 7.3386 ] Assuming zero filled SBK key
17:28:58 INFO: Flash Jetson Linux - flash: [ 7.3521 ] Warning: pub_key.key is not found
17:28:58 INFO: Flash Jetson Linux - flash: [ 7.2980 ] tegrahost_v2 --chip 0x19 0 --updatesigheader blob_tegra194-p3668-0000-p3509-0000_aligned_sigheader.dtb.encrypt blob_tegra194-p3668-0000-p3509-0000_aligned_sigheader.dtb.hash zerosbk
17:28:58 INFO: Flash Jetson Linux - flash: [ 7.3186 ] tegrahost_v2 --chip 0x19 --generateblob blob.xml blob.bin
17:28:58 INFO: Flash Jetson Linux - flash: [ 7.3210 ] number of images in blob are 11
17:28:58 INFO: Flash Jetson Linux - flash: [ 7.3216 ] blobsize is 6500424
17:28:58 INFO: Flash Jetson Linux - flash: [ 7.3219 ] Added binary blob_nvtboot_recovery_cpu_t194_sigheader.bin.encrypt of size 232976
17:28:58 INFO: Flash Jetson Linux - flash: [ 7.3321 ] Added binary blob_nvtboot_recovery_t194_sigheader.bin.encrypt of size 206016
17:28:58 INFO: Flash Jetson Linux - flash: [ 7.3331 ] Added binary blob_preboot_c10_prod_cr_sigheader.bin.encrypt of size 24016
17:28:58 INFO: Flash Jetson Linux - flash: [ 7.3338 ] Added binary blob_mce_c10_prod_cr_sigheader.bin.encrypt of size 145184
17:28:58 INFO: Flash Jetson Linux - flash: [ 7.3349 ] Added binary blob_mts_c10_prod_cr_sigheader.bin.encrypt of size 3430416
17:28:58 INFO: Flash Jetson Linux - flash: [ 7.3434 ] Added binary blob_bpmp-2_t194_sigheader.bin.encrypt of size 1007392
17:28:58 INFO: Flash Jetson Linux - flash: [ 7.3459 ] Added binary blob_tegra194-a02-bpmp-p3668-a00_lz4_sigheader.dtb.encrypt of size 36176
17:28:58 INFO: Flash Jetson Linux - flash: [ 7.3506 ] Added binary blob_spe_t194_sigheader.bin.encrypt of size 95232
17:28:58 INFO: Flash Jetson Linux - flash: [ 7.3514 ] Added binary blob_tos-optee_t194_sigheader.img.encrypt of size 977664
17:28:58 INFO: Flash Jetson Linux - flash: [ 7.3534 ] Added binary blob_eks_t194_sigheader.img.encrypt of size 5136
17:28:58 INFO: Flash Jetson Linux - flash: [ 7.3544 ] Added binary blob_tegra194-p3668-0000-p3509-0000_sigheader.dtb.encrypt of size 340032
17:28:58 INFO: Flash Jetson Linux - flash: [ 7.3746 ] Sending bootloader and pre-requisite binaries
17:28:58 INFO: Flash Jetson Linux - flash: [ 7.3775 ] tegrarcm_v2 --download blob blob.bin
17:28:58 INFO: Flash Jetson Linux - flash: [ 7.3796 ] Applet version 01.00.0000
17:28:58 INFO: Flash Jetson Linux - flash: [ 7.4310 ] Sending blob
17:29:00 INFO: Flash Jetson Linux - flash: [ 7.4313 ] [... ] 016% [ 7.4313 ] [... ] 032% [ 7.4313 ] [... ] 048% [ 7.4313 ] [... ] 064% [ 7.4313 ] [... ] 080% [ 7.4313 ] [...] 096% [ 7.4313 ] [...] 100%
17:29:00 INFO: Flash Jetson Linux - flash: [ 8.8587 ] tegrarcm_v2 --boot recovery
17:29:00 INFO: Flash Jetson Linux - flash: [ 8.8617 ] Applet version 01.00.0000
18:19:46 INFO: Flash Jetson Linux - flash: [ 9.9331 ] tegrarcm_v2 --isapplet
18:19:46 INFO: Flash Jetson Linux - flash: [ 1023.7076 ] tegrarcm_v2 --ismb2
18:19:46 INFO: Flash Jetson Linux - flash: [ 2039.5310 ] tegradevflash_v2 --iscpubl
At the end I got tired of waiting and disconnected the board.
Any help would be highly appreciated.
Thank you,
Luis
SDKM_logs_JetPack_5.1.2_Linux_for_Jetson_Xavier_NX_modules_2023-11-13_17-24-55.zip (51.0 KB)
Please also dump serial console log as instructed here:
Sorry I do not have the USB-serial device available now
Then it’s hard to further allocate the issue.
I can only suggest trying more times or maybe switching for a different host PC or USB cable/port.
I have an USB-232 header that I will have to take apart, but I do not know if it will work because it is old.
If I get it working: when does the logs need to be captured? During the whole flashing process?
YES, please capture log during the whole flashing process.
