I’ve been attempting to import a Delta Robot arm into Isaac Sim from OnShape. If the assembly includes a ball-joint, it will not import into Isaac Sim. The Onshape Importer appears, and it looks like its downloading, but nothing populates into the 3D workspace or tree. If I go back to OnShape, and change the joint to revolute, then it imports just fine. I’ve experimented going back and forth between joint types and the issue is repeatable. I’m not sure if I’m doing something wrong or if this is a bug in the importer.
Related topics
| Import onshape assembly to Isaac Sim 2022.1.0 | 2 | 604 | April 5, 2024 | |
| Isaac Sim Onshape Importer Extension - Propellers not attached while importing custom drone | 5 | 194 | October 15, 2024 | |
| Isaac Joint inspector does not recognize all degrees of freedom for custom robot | 4 | 530 | March 13, 2023 | |
| Parallel Robot similar to Stewart platform physx issue | 6 | 303 | May 5, 2025 | |
| Onshape import does not work Omniverse Technical Issue/bug | 4 | 734 | August 11, 2023 | |
| Different between OnShape and Isaac Sim | 4 | 120 | June 3, 2025 | |
| I get different coordinates per parts when importing via OnShape and the Pivot Tool seems to be bugged right now | 0 | 110 | June 14, 2024 | |
| Trouble importing onshape assembly that has subassemblies | 2 | 516 | July 27, 2023 | |
| Problems importing Onshape models into Isaac Sim | 0 | 258 | May 21, 2024 | |
| Import from onshape fails in IsaacSim 4.5 | 0 | 85 | February 13, 2025 |
