Issue with cudaMemPrefetchAsync on drive orin device
Software Version
DRIVE OS 6.0.10.0
DRIVE OS 6.0.8.1
DRIVE OS 6.0.6
DRIVE OS 6.0.5
DRIVE OS 6.0.4 (rev. 1)
DRIVE OS 6.0.4 SDK
other
Target Operating System
Linux
QNX
other
Hardware Platform
other
SDK Manager Version
2.1.0
other
Host Machine Version
other
Issue Description
I tried the simple sample of cuda in my drive orin device and tries to use cudaMemPrefetchAsync. But even though i can detect my cuda device, it still has error of cudaMemPrefetchAsync. Did you make something wrong in my code?
$ ./vectorAdd
Device count: 1
Using device 0: Orin (CC 8.7)
[UM VectorAdd N=50000000 (190.73 MiB per array), reps=5]
vectorAdd.cu:305 invalid device ordinal
#define CHECK(x) do{ cudaError_t e=(x); if(e){fprintf(stderr,"%s:%d %s\n",__FILE__,__LINE__,cudaGetErrorString(e)); exit(1);} }while(0)
int main(int argc, char** argv){
     int count = 0;
    CHECK(cudaGetDeviceCount(&count));
    printf("Device count: %d\n", count);
    int dev = 0;  // Or parse from argv, then clamp to [0, dev_count)
    cudaSetDevice(dev);
    cudaDeviceProp prop{};
    cudaGetDeviceProperties(&prop, dev);
    printf("Using device %d: %s (CC %d.%d)\n", dev, prop.name, prop.major, prop.minor);
    // --- problem size ---
    int N    = (argc>1)? atoi(argv[1]) : 50000000; // default 50M elements
    int reps = (argc>2)? atoi(argv[2]) : 5;
    size_t bytes = (size_t)N * sizeof(float);
    printf("[UM VectorAdd N=%d (%.2f MiB per array), reps=%d]\n",
           N, bytes/1024.0/1024.0, reps);
    // --- Unified Memory allocation ---
    float *A, *B, *C;
    CHECK(cudaMallocManaged(&A, bytes));
    CHECK(cudaMallocManaged(&B, bytes));
    CHECK(cudaMallocManaged(&C, bytes));
    // --- initialize on host ---
    for (int i=0;i<N;i++){ A[i]=rand()/(float)RAND_MAX; B[i]=rand()/(float)RAND_MAX; }
    // --- prefetch to GPU 0 ---
    CHECK(cudaMemPrefetchAsync(A, bytes, dev));
    CHECK(cudaMemPrefetchAsync(B, bytes, dev));
    CHECK(cudaMemPrefetchAsync(C, bytes, dev));
    CHECK(cudaDeviceSynchronize());
     return 0;
Dear @rlu1 ,
Could you check if /usr/local/cuda/samples/1_Utilities/UnifiedMemoryPerf sample working and see the usage of API for reference?
okay, thanks
