Issue with Custom Carrier Board for Jetson AGX Orin: Wi-Fi Card Connected via SDIO Fails to Detect Any Wi-Fi Access Points
I am using the AP6276s Wi-Fi card and currently facing an issue where the device detects the Wi-Fi card but is unable to scan for any internet access points. Below is the log when inserting the bcmdhd.ko module.
log porting wifi.log (9.7 KB)
If the device cannot be flashed/booted, please refer to the page to get uart log from the device:
Jetson/General debug - eLinux.org
And get logs of host PC and Jetson device for reference. If you are using custom board, you can compare uart log of developer kit and custom board to get more information.
Also please check FAQs:
Jetson AGX Orin FAQ
If possible, we would suggest follow quick start in developer guide to re-flash the system:
Quick Start — NVIDIA Jetson Linux Developer Guide 1 documentation
And see if the issue still persists on a clean-flashed system.
WIFI through SDIO is not supported. Please check
Jetson Orin Series — NVIDIA Jetson Linux Developer Guide 1 documentation
Would suggest use PCIe interface.
