换了wifi6也是不行。
0001:00:00.0 PCI bridge: NVIDIA Corporation Device 229e (rev a1) (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 188, IOMMU group 3
Bus: primary=00, secondary=01, subordinate=ff, sec-latency=0
I/O behind bridge: [disabled]
Memory behind bridge: 40000000-400fffff [size=1M]
Prefetchable memory behind bridge: [disabled]
Capabilities:
Kernel driver in use: pcieport
0001:01:00.0 Network controller: Intel Corporation Wi-Fi 6 AX200 (rev 1a)
Subsystem: Intel Corporation Wi-Fi 6 AX200NGW
Flags: fast devsel
Memory at 20a8000000 (64-bit, non-prefetchable) [disabled] [size=16K]
Capabilities:
0004:00:00.0 PCI bridge: NVIDIA Corporation Device 229c (rev a1) (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 190, IOMMU group 5
Capabilities:
0004:01:00.0 Non-Volatile memory controller: MAXIO Technology (Hangzhou) Ltd. NVMe SSD Controller MAP1202 (DRAM-less) (rev 01) (prog-if 02 [NVM Express])
Subsystem: MAXIO Technology (Hangzhou) Ltd. NVMe SSD Controller MAP1202
Flags: bus master, fast devsel, latency 0, IRQ 190, NUMA node 0, IOMMU group 5
Memory at 2428000000 (64-bit, non-prefetchable) [size=16K]
Capabilities:
Kernel driver in use: nvme
Kernel modules: nvme
0008:00:00.0 PCI bridge: NVIDIA Corporation Device 229c (rev a1) (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 186, IOMMU group 31
I/O behind bridge: 00000000-00000fff [size=4K]
Capabilities:
0008:01:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168/8211/8411 PCI Express Gigabit Ethernet Controller (rev 15)
Subsystem: Realtek Semiconductor Co., Ltd. RTL8111/8168 PCI Express Gigabit Ethernet controller
I/O ports at 300000 [size=256]
Memory at 3528004000 (64-bit, non-prefetchable) [size=4K]
Memory at 3528000000 (64-bit, non-prefetchable) [size=16K]
Capabilities:
Kernel driver in use: r8168
Kernel modules: r8168
