although sdkmanager failed to install jetpack-4.3 on my custom TX2 board, I installed it by using
sudo ./flash.sh jetson-tx2 mmcblk0p1
after hand-editing rootfs/etc/shadow to be able to log in as root on the serial line.
I tried to use jetson-io, but discovered it is not installed, then I discovered the .deb packages
in /opt/nvidia/l4t-packages. It seems that I must install nvidia-l4t-ccp-t186ref_32.3.1-20191209230245_arm64.deb, but that fails with a error message that I don’t find how to solve :
root@linux:/opt/nvidia/l4t-packages/userspace# dpkg -i nvidia-l4t-ccp-t186ref_32.3.1-20191209230245_arm64.deb
(Reading database ... 119033 files and directories currently installed.)
Preparing to unpack nvidia-l4t-ccp-t186ref_32.3.1-20191209230245_arm64.deb ...
L4T Debian install is not supported on your configuration
You should install an L4T image from the latest releases - starting
from r32.3+ to have Debian package support
dpkg: error processing archive nvidia-l4t-ccp-t186ref_32.3.1-20191209230245_arm64.deb (--install):
new nvidia-l4t-ccp-t186ref package pre-installation script subprocess returned error exit status 1
Errors were encountered while processing:
It is actually fairly simple to flash on command line. The only time SDK Manager/JetPack is required is for the extra optional package installs. If you look at your “~/nvidia/nvidia_sdk/JetPack_4.2_Linux_P3310/” (where the release version will change…thus “4.2” is bold faced font), then you will see the “Linux_for_Tegra/” subdirectory. This is the driver package (and within this the “Linux_for_Tegra/rootfs/” is the unpacked sample rootfs), and flash.sh is part of the driver package.
If you cd to the “Linux_for_Tegra/” of your release, and have the TX2 in recovery mode with the micro-B USB connected, then this will flash (do keep in mind the “rootfs/” must be populated…if you ever tried to flash this will already be populated, and if not, then there will just be a README file in “rootfs/”):
If your “rootfs/” is empty, and you need information on unpacking the sample rootfs, just ask. Any previous attempt to flash would have populated this and you won’t need to populate rootfs each time.
NOTE: If you then run SDKM at a later date, then you can just uncheck flash and simply add extra packages without flashing again.
