JetPack 4.4.1 Production Release with L4T 32.4.4
Just received a Nano 2GB a couple hours ago, used Getting Started guide, downloaded jetson-nano-2gb-jp441-sd-card-image.zip burnt it onto a 64GB sd card, and connected it my TV - TV reports 1080p resolution.
The UI is UNUSABLE ! The fonts are incredibly small!
I opened Chromium and searched how to make fonts bigger (Chromium has properly sized fonts). I found fonts were Sans with a size of 11 (and in a few places, 10), put them on 16… still looks very small!
Not to mention, that I received 2 windows with errors on the first boot process - which I couldn’t read because the font was also too small.
This is frustrating… I was expecting a properly working product from NVIDIA, now I have to fix the linux distro instead of running and learning from the cool demos that are available…
Is there a previous version that has properly sized fonts at 1080p?
I see there is a related issue opened: Initial boot configuration succeeds but unminimize command fails and changes the desktop in a bad way (10/21/2020 Nano Image)
please, please fix this ASAP, this board should be easy-to-use not hard-to-fix-to-use.
Let me know if you need more details, but please try the image above on a TV with 1080p.
Regards,
Adrian
