I’m using etcher, and via HDMI it’s working fine, but I want to use headless setup.
If I create an image with jetson-disk-image-creator.sh it’s working fine.
Hi tvai,
Please try again and remove your HDMI cable.
And check /dev/ttyACMx on your host ubuntu machine.
It’s already what I did so many times.
The screenshots I sent was connecting the HDMI cable after oem-config detects it’s headless setup, just to see the output when I get an error.
When it fails, I have only USB cable to my PC connected and power cable.
I just tried again:
- flash nv-jetson-nano-sd-card-image-r32.4.2.zip to a SD card with etcher
- connect USB cable to my host (running up to date ubuntu 18.04)
- connect power cable to J25 (with J48 ON)
- sudo picocom -b 115200 /dev/ttyACM0
I get the welcome screen, when I press OK with Enter key of a French keyboard, I get disconnected, and then when I run again the picocom command, I get the login screen with "localhost.localdomain login: "
Last friday I did theses steps 5 times, and same result.
Let me try with r32.3.1.
Hi tvai,
I am just wondering… does this issue still happen to sdcard image or even sdkmanager would hit this?
In your previous case, you said older sdcard image should not hit such issue but only latest rel-32.4.2 image will. Is this comment still true?
I’m trying it right now.
Yesterday I tried to create an image with the following steps, and the oem-config of the generated image was working fine, pressing OK on the welcome screen did not eject me and I could finish all the oem-config process.
tar xvpf /sdkm_downloads/Jetson-210_Linux_R32.4.2_aarch64.tbz2
cd Linux_for_Tegra/rootfs
sudo tar xvpf /sdkm_downloads/Tegra_Linux_Sample-Root-Filesystem_R32.4.2_aarch64.tbz2
cd ..
sudo ./apply_binaries.sh
sudo tools/jetson-disk-image-creator.sh -o sd-blob-b01.img -b jetson-nano -r 300
I confirm you that flashing r32.3.1 image is working.
Just want to make sure about this again. Sorry in advance If you mentioned somewhere before.
- Have you tried other Nano devkit (if you have it)
- Have you tried other sdcard?
- Have you tried other host machine?
- Yes, I tried another nano devkit
- Yes, I tried another sdcard
- I would say yes, but right now I can’t test on another computer
This seems very strange because if I flash the r32.3.1 on the same SD, run it on the same nano and connect from the same PC, and it’s working fine.
I’ve seen many posts about people complaining about the r32.4.2 image not working in headless setup, maybe there is something that you don’t reproduce on your lab, but that happens on many computers over the world.
I don’t think I have a strange config, it’s a PC running ubuntu 18.04 in english (french keyboard, english locale), and I just hit “Enter” key on my keyboard, nothing more.
Ok, we will firstly check your oem-config.log.
thanks,
I didn’t pay any attention but if you look at the log, it’s saying something about length of license… maybe it’s a clue, the license is maybe longer than the r32.3.1 one, and that could explain why it’s working on desktop, but not in headless setup.
One test could be to flash the SD card, mount it to reduce the size of the license, and test it in a nano devkit.
That could explain also why creating my own image with jetson-disk-image-creator.sh is working, I guess the license file is different from the official image.
I confirm you what I said before:
with exactly the same nano devkit, same PC, same SD card, I modified the license inside the SD card after flashing it with etcher, from my PC:
sudo mkdir /mnt/nano_sd_p1
sudo mount /dev/sdc1 /mnt/nano_sd_p1
sudo gzip -d "/mnt/nano_sd_p1/usr/share/doc/nvidia-tegra/NVIDIA End User License Agreements.txt.gz"
sudo vim "/mnt/nano_sd_p1/usr/share/doc/nvidia-tegra/NVIDIA End User License Agreements.txt"
# I kept the first 50 lines more or less
sudo gzip "/mnt/nano_sd_p1/usr/share/doc/nvidia-tegra/NVIDIA End User License Agreements.txt"
sudo umount /mnt/nano_sd_p1
is working fine
May I know your md5 checksum of sdcard image? I just consulted with internal team and they said this issue was already resolved and new sdcard image is on the download center. (and yes, it is really due to the large license content)
Please check if your have below md5sum for sd image.
ebdf7b0ffdb3539606c654105466f956
Indeed, my file is “nv-jetson-nano-sd-card-image-r32.4.2.zip” with md5 “8cf36d838fe199ec7bef5f618b7c0aef” I downloaded it on 2020-04-30.
I downloaded the last one “nv-jetson-nano-sd-card-image-r32.4.2b.zip” with md5 “ebdf7b0ffdb3539606c654105466f956”, and indeed the problem is fixed.
Sorry for all this long post, I didn’t know about a new version with same version number. I should have downloaded it first.
I understand now why it may have worked once, I guess it was from my office computer, and not home computer.
We can mark this post as resolved.
Last post I sent is not relevant, I get the same log when setting an IP, so I think it’s normal as I don’t have an Ethernet cable connected.
Just ignore my previous post.
Hi tvai,
Yes, it’s normal behavior.
After finish the oem-config setting, the term will be closed.
Please change to using TX/RX/GND pins and get uart logs. (/dev/ttyUSB*)
