Jetpack 5.1.2 creates small partition on nvme drive instead of using all the space
I would like to upgrade my xavier NX to use Jetpack 5.1.2 so that I can hit the ESC key on startup. The keyboard doesn’t work while booting with my current install of Jetpack 5.1.1 (rev. 1).
The problem is that I have a 256 GB NMVE SSD and 5.1.2 installs on a tiny partition of 16 GB at the front while 5.1.1 (rev. 1) installs it at a large 255 GB partition at the back.
Is this a problem that anyone else is seeing? I am just using the SDK manager to install and it will fail at the runtime or SDK components due to lack of space.
This is what the disk looks like on Jetpack 5.1.1 (rev. 1)
This is what the disk looks like on Jetpack 5.1.2
I’ve tested 4 different jetpack versions and have ran into some set of problems on the latest three. For now it seems like I have to revert to use 5.0.2 (rev 2)
Jetpack 5.1.2 - can access boot menu but creates small partition on nvme drive
Jetpack 5.1.1 (rev. 1) - uses whole nvme but can’t access boot menu
Jetpack 5.1 (rev 1) - uses whole nvme but can’t access boot menu
Jetpack 5.0.2 (rev 2) - uses whole nvme and can access boot menu
Please do this:
That worked! Thank you
