When JetPack 5.1.4 flashes the system to nvme, the partition size is only 14G, not the entire nvme space size
Hi
You’ll want to edit the partition layout: How to flash and boot a Jetson from NVMe SSD - RidgeRun Developer Wiki
Regards,
Allan Navarro
Embedded SW Engineer at RidgeRun
Contact us: support@ridgerun.com
Developers wiki: https://developer.ridgerun.com/
Website: www.ridgerun.com
Hi.Alian
Thank you very much. I used SDKManager to burn the program. I referred to the solution in the following link, but it didn’t work. Which files should I modify?
However, I will try the method you mentioned later.
Regards,
ziv
