Does anyone know system requirements (ubuntu) for host installation?
I am facing problems when install cuda toolkit on host, it complains that dependencies were not successfully installed (samples and documents were failed).
Hi dungta28888.ansv, which JetPack version are you using?
For Jetpack 3.2, Ubuntu 16.04 x86_64 on the host-side is supported.
Does the host have an NVIDIA video card? CUDA can only go on the host if the GPU is there.
My host has no gpu
The host should be able to install packages to the Jetson, or flash the Jetson…but it won’t be able to run CUDA applications directly on the host.
@dusty_nv: I am trying to install JetPack 3.1 on Jetson TX2.
