The Jetson AGX module runs video encoding and decoding, and the video data is transmitted through PCIe. When the Jetson module performs EP, there is a probability of abnormality in the environment of 0 degrees. Print the following log
We would need to reproduce the issue first and check further. The latest release is Jetpack 4.6 and if you use a previous release, suggest upgrade to latest release and try again. If the issue is still present, please share us a way to reproduce the issue on Xavier developer kit.
